Pre load of diff bearings. - Defender Source
Old October 9th, 2003, 03:03 AM
andersoriginal
Anders Thornberg
Defender 110 2003
On my 110 Defender 2003 I have now the diffs wide open, installing ARB lockers both front and rear.
I have two workshop manuals, but noone is giving me the specification of how to preload the differential bearings.
This is LR axles. Not shimed, but they use nowdays 2 big nuts to adjust the backlash and preload. One nut on each side, big as the bearing.
Anyone having any idea? Free beer in Sweden for a good advice.
all the best
Anders
Old October 9th, 2003, 02:14 PM
If it is different then this
http://www.defendersource.com/tech/arb.html
then I would say not too many people on this board would know, because this is the way most of are diffs are set up. You could also try here
http://www.lrenthusiastforum.com/ubb...s.php?Cat=&C=1
I am not tring to send you away, Just tring to help
Old October 9th, 2003, 03:33 PM
andersoriginal
Anders Thornberg
Defender 110 2003
Been there, been everywhere. No pre-load figures. I must be the only one with this problem.
regards
anders
Old October 9th, 2003, 04:29 PM
Did you try asking at the Dealership? They would have to knw as they would possibly have to fix it. I'm sure if you walked in with a six pack you could walk out with an answer!
Old October 9th, 2003, 11:39 PM
andersoriginal
Anders Thornberg
Defender 110 2003
I did. Got them from Mat Savage in GB. Hasnīt got a clue. Just selling. Hopless to be stuck here in the middle.
But I have the rear one untuched. I think I will measure this on before I change to the ARB and then preload the new bearings as tight as the original was.
You know I got two workshop manuals - no one cures this problem.
First one in universe to fit ARB lockers to LR Defender 2003 axles? Of course not - someone out there is sitting on the right answere.
all the best
Anders
Old October 10th, 2003, 06:42 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I will let you know later today about the specs. It is in one of my books.
Old October 10th, 2003, 08:08 AM
I was looking at 2 of my manuals and they show the bearing nuts being torked to 90 NM. They say to tighten them until there is no play then tork them down. You are talking about the nuts that go over the bearings? The ones that you need a spiecal tool to put on and take off?
Old October 10th, 2003, 08:43 AM
Look here
http://www.landrover.ee/est/files/ma..._WSM_book3.pdf
Scroll down to page 132 of 136
Look at # 29, is this the nut you are talking about?
Old October 10th, 2003, 04:01 PM
andersoriginal
Anders Thornberg
Defender 110 2003
Got it! At last. You saved my weekend. Thanks a lot Randy, Mike and Michael. Free beer and dinner in Sweden.
Al the best
Anders
Old October 10th, 2003, 04:08 PM
COOOOLLL!!!!!
Time to take it out and test it!
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
Diff Bearings jimmy salmon Defender Technical Discussions 10 October 12th, 2006 05:22 PM
QT Services Diff Guards and HD Engine Mounts JohnC The Vendors Loft 1 February 16th, 2006 09:53 PM
need front/rear diff for 1994 D90 rover_rich_d90 Wanted 4 March 14th, 2005 09:05 PM
ST rear load space matt in SW? Seriesman Defender Technical Discussions 6 November 2nd, 2004 12:44 AM
