PRC7371 Domelight switch pinout? - Defender Source
Old January 7th, 2015, 03:45 PM
Does anybody have the pinout for this switch? It would sure make my life easier than figuring it out with my trust fluke multimeter.
Old January 7th, 2015, 04:03 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Blue/white - to dome light
Blue - +12 volt
Red - fuse box
Red/white - instrument lights
Old January 7th, 2015, 04:29 PM
I don't have the harness. I am looking for the actual switch pinout.
Old January 7th, 2015, 04:31 PM
rankar's Avatar
rankar
I'll get it to you tonight when I'm back with my 90
Old January 7th, 2015, 04:57 PM
Thanks Randy!
Old January 8th, 2015, 02:27 AM
rankar's Avatar
rankar
Dave I'll check it out tomorrow (later today). I got home in 8 F weather and chickened out.
Old January 8th, 2015, 09:19 AM
Don't freez your ass off Randy. I busted out the Fluke and figured it out. The top 2 pins make one circuit and the bottom two pins make another.
Old January 8th, 2015, 09:30 AM
rankar's Avatar
rankar
I saw the sun shining and thought, let me go out and look and see what I did with wiring (i wanted to have this mod because it's cool, but don't think it's stock in NAS). It was -1 F outside.
I looked up the wiring and it's supposed to be purple and purple/white (i'm color blind, so in my mind it was blue when I was putting it together).
Here's some more info for your wiring:
Switch engaged in top position: all interior lights on
Switch in middle position: all interior lights off
Switch engaged in down position: all gauge lights off
Hope this helps.
EDIT:
Ok Dave, found this from the lr4x4 guys on the wiring:
purple/white trace from switch to interior light +ve connection
plain purple is the permanent 12v feed shares with clock if fitted.
plain red from fusebox & sidelight warning light in dash panel
red/white trace to instrument lighting
ht, switch
Rear Defrost Switch, Rear Wiper Switch, and Rear Wipe/Wash Switch bradfordish For Sale - Parts 5 January 26th, 2014 12:30 PM
Rollover switch? Fuel pump kill switch? tebby Defender Technical Discussions 1 July 9th, 2013 01:23 PM
2.5 L Diesel Ignition Switch Pinout javelinadave Defender Technical Discussions 7 June 1st, 2013 11:09 PM
Aux. light switch (RRC headlight switch) $40 shipped evilfij For Sale - Parts 0 September 5th, 2008 05:12 PM
ECU pinout for 1995 D-90 boxerhips Defender Technical Discussions 8 January 13th, 2006 01:51 PM
