PPI NEEDED in Ontario, California - Page 4 - Defender Source
Old February 8th, 2012, 09:39 AM
Daily driver
Designated driver
Dunkin donuts
Old February 8th, 2012, 09:49 AM
pipermalibu's Avatar
pipermalibu
Bryan Adams
97 D90
ahhh - that kind of reinforces my thoughts. He has a SW, and does not state that he has a fiberglass hard topped ST. D90Tops himself said I would have water coming in around the roll bars and door tops. My friend has a 97 SW and has no water coming in at all except the front vents (which I am going to fix for him).
Old February 8th, 2012, 10:17 AM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
Originally Posted by rijosho View Post
Daily driver
Drunk driver
Dunkin donuts
fixed it. and yes.
Old February 8th, 2012, 11:37 AM
In all seriousness Bryan, with your stated goals I think you should have bought a SW. ST trucks are for taking the top off and not worrying about water ingress.
The good news is that other than a lot of work, you have the upper hand on a ST to SW swap for parts. But I wouldn't do it.
Originally Posted by pendy
I'm here for the D's
Old February 8th, 2012, 12:09 PM
Bryan,
Call and find out about the Rover Racks hard top... Brand new, delivered $4K, and can be painted to match.
Old February 8th, 2012, 01:25 PM
Originally Posted by pipermalibu View Post
Therefore, I am going to attempt the futile of zero water egress. I am actually think to seal the dash vents even, like the new Defenders that come from the factory now.
I would personally recommend the aluminum roof.
Fiberglass, unless it was S-glass unidirectional VARTM, is way too weak. I can only imagine that most if not all of the fiberglass tops out there are chopped-spray layup construction. The tensile modulus is just so much lower than the elastic modulus due to the low fiber fraction volume.
IMHO, if you have the proper seals between the roof, sides, and windshield top, your only worry about water ingress is the door tops.
I personally don't find much if any water ingress from the dash vents.
Old February 8th, 2012, 01:30 PM
This time in English Kang!
Old February 8th, 2012, 01:41 PM
He said "you should have bought a SW". LOL
Old February 8th, 2012, 01:55 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Ideally if you want a SW, might as well just buy a SW. But, if you're positive that this is "the truck", you can swap to a metal hardtop pretty easily. The soft top cage is sought after, so you might even find someone to trade a metal hardtop/cage for your soft top/cage. It takes some time but isn't very difficult to do the swap. If you want the option to go topless easily, then you might look at the fiberglass top from d90 tops.
Old February 8th, 2012, 02:07 PM
He'll also want one piece doors and likely need to paint. All sounds like it's not worth it to me.
Old February 8th, 2012, 02:12 PM
The POE trucks had 2-piece doors with a SW, so technically wouldn't the doors be able to work?
Old February 8th, 2012, 02:15 PM
I said want not need. He wants no leaks and a quiet interior. Keep up man!
Old February 8th, 2012, 02:20 PM
Shouldn't he get a Chevy Volt or a Prius then?
Series spotted in Ontario, California Overland90 Series Technical Discussions 0 January 2nd, 2009 04:05 PM
California Spec Defender? Captain Spalding Defender Technical Discussions 19 March 24th, 2006 11:07 PM
Spare Tire needed Andrew Vick Wanted 0 March 15th, 2006 01:57 PM
Replacing Alt, H20 pump, fan clutch, and belts - Advice needed arbik Defender Technical Discussions 3 January 7th, 2006 09:11 AM
What Parts Are Needed For A P/U Cab? javelinadave Defender Technical Discussions 6 October 25th, 2003 09:48 AM
