Pozidrive Bits - Defender Source
Old September 22nd, 2006, 11:34 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Pozidrive Bits
Anyone know where I can find some posidrive #4 bits? I have ordered stainless replacement bolts (Mud UK)
and am having trouble locating these bits. I read on another post that I need size #4, but if anyone knows any different, or has any advice other than what has been posted, I would really appreciate it.
Old September 23rd, 2006, 12:01 AM
R. Kurk
Richard Kurk
1993 110 NAS #489
I bought a Snap-on 3/8" #4 Pozidriv and it works very well. It's hard to imagine trying to get the existing bolts out without a socket that is an exact and proper fit, and will stand A LOT of torque to break the bolts loose.
Here is a link to the Snap-on socket (not cheap but well made)
http://buy1.snapon.com/catalog/item....re&dir=catalog
Old September 23rd, 2006, 12:09 AM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Apex (Division of Cooper Tools) makes them - should be available through any Grainger.
Old September 23rd, 2006, 04:23 PM
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Perfect, thanks.
Old September 23rd, 2006, 05:51 PM
You dont need a pozi bit, but if you are trying to get the door bolts out you probably do need an impact driver.
They cost less than 20 bucks at Sears and they simply look like a black tube with a bit at one end. Mine came with a suitable bit for removing the door bolts. Just whack the end with a rubber mallet and very stuck fasteners will loosen very quickly.
Old September 23rd, 2006, 06:00 PM
Or hook up the appropriate socket to your IR2131Ti impact gun and fire away.
Old October 3rd, 2006, 09:34 PM
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Well, I ordered and recieved the snap-on pozidrive bit. It worked for the passenger side up until the last bolt, and then it crumbled into pieces. So, I called Snap-On, and they are sending me another. The mud bolts look good, but are a little short for the inside of the doors. Unless I did something wrong, they wouldn't hurt to be about 1/4 in. longer. I could barely get the nut on the threads inside the upper door panels. And there definitely wasn't room for the washers. I tried to do only one section at a time, as recommended, but in the end I had to loosen them all to readjust the door for proper alignment.
Old October 3rd, 2006, 10:58 PM
The MudUK bolts have the same problem that all other aftermarket bolts do - they werent painted on the truck. You have to be very careful to fully seat the bolts. Of course they might also be too short!
Old October 4th, 2006, 07:55 AM
GeoParth's Avatar
GeoParth
George Parthmer
1995/d-90 #2715 yellowST
if i recall, the MUD bolts didnt come with lock nuts but did have the standard slip-off after a month kind. i think i sourced them elsewhere but they werent stainless.
Old October 4th, 2006, 09:26 AM
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
They do come with lock bolts, but they are a bit short. I need to know the name of a product that will remove the rust stains from the hinges easily. I don't want to start the drivers door until I have a good rust remover.
Old July 14th, 2010, 08:58 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Has anyone bought a #4 pozidriv lately? I checked at Snap-On, Matco, McMaster, Grainger, Northern Tool, Sears and of course useless Home Depot & Lowes and no one has them. I like the look of the Snap-On and would like to find something similar
Old July 14th, 2010, 09:18 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Buy an impact driver at Home Depot, it comes with a few bits one of which is a #4 Posidrive
« Puma? | AC install »
Parting out 1993 NAS 110 bits ECR For Sale - Parts 10 October 16th, 2009 08:22 PM
Roll up door bits mightymg Wanted 2 September 15th, 2009 10:20 PM
90 to 110 Conversion Leftovers Bits Pricing Wolf Fabrication Defender Technical Discussions 4 July 12th, 2009 10:54 AM
Wanted : A few D90 Soft Top bits extreamlandy90 Wanted 9 March 15th, 2008 07:45 AM
Another one bits the dust Mike Hippert Misc. Chit-Chat 29 November 23rd, 2005 07:22 PM
