powertank problem - Defender Source
Old March 27th, 2008, 07:16 PM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
powertank problem
last time I went wheeling, my regulator (the big silver knob you turn) froze up and wont budge. It wont move, with the main, black screw valve open or closed, it doesnt matter.
As you can see, there is still pressure in the regulator. I can't bleed it out, since the knob wont turn.
Has anyone else experienced this problem.
According to my estimates, I should still have 7-8lbs of CO2 in the tank. I have only tried turning the knob with my bare hands.
Any ideas?
ID:	12774   Click image for larger version
Old March 27th, 2008, 08:00 PM
Try moving it with a pair of Channel locks. Another option is to plug the hose in and bleed the air out that way.
Another option is to call Powertank, they are still open since they are in Cali. I have two tanks, and they their service has been great.
Old March 30th, 2008, 10:38 AM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
Any ideas?
Jeff,
Just shut the main tank valve and crack the nut, there is alot of pressure but very little volume, you will be fine, I have forgoton to blead off my regulator on the argon tank on my welder and removed the regulator, about 2500 psi. you will hear a little pop and air excape but probebly not enough to blow wind through your hair.
MH
--Benjamin Franklin
Wobbly distributor cap? and an update on my starter problem MiniGuy Defender Technical Discussions 6 January 10th, 2006 10:13 AM
Air Locker problem sflash868 Defender Technical Discussions 1 May 9th, 2005 09:40 AM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
Powertank July Special Maine 110 The Vendors Loft 0 July 14th, 2004 03:56 PM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
