Power windows with factory powered regulators? - Defender Source
Old April 28th, 2014, 10:06 AM
bradfordish's Avatar
bradfordish
Bradford
95 D90 SW #141
I currently have retrofitted power windows using the Spal kit which works off of the hand crank assembly. It works ok, but not great. I'm going to need to replace my passenger side regulator soon anyways (believe it has gotten bent), and was wondering about putting in powered regulators from a Disco or the later model Defender powered regulators (CUH000082).
In a few searches on here it looks like some people have done this, but I can't seem to figure out which ones they used. Any and all advice, suggestions, etc. is greatly appreciated.
Old April 28th, 2014, 10:25 AM
phoenix37's Avatar
phoenix37
john
I purchased a kit from http://safarihp.com and had british car service in LA install them in my 110. Might be worth a call to one of those guys. I will tell you the BCS guys said it was so difficult to get it right they would never do it again.
Old April 28th, 2014, 10:48 AM
bradfordish
Bradford
95 D90 SW #141
That doesn't sound encouraging! Fitting the spal unit alone was a PITA given the limited room between the door and door card.
Old April 28th, 2014, 10:56 AM
depends on which doors you have the later doors and power regulators are easier than the earlier ones.
Old April 28th, 2014, 11:09 AM
bradfordish
Bradford
95 D90 SW #141
I have the original doors that came on my 95 SW. What kind of fitment issues/modifications am I potentially looking at?
Old April 28th, 2014, 11:12 AM
phoenix37's Avatar
phoenix37
john
it was an Nas 110 with stock doors
Old April 28th, 2014, 12:00 PM
If you're doors are rusty you could always just replace them with some newer style doors that already are set up for power windows.
Old April 28th, 2014, 12:30 PM
bradfordish
Bradford
95 D90 SW #141
Fortunately or unfortunately in this case, they are clean as a whistle both inside and out (something pretty remarkable).
Old April 28th, 2014, 12:38 PM
phoenix37's Avatar
phoenix37
john
If i recall the kit cost me 1k and installation 1200..Not sure what a set of doors with power windows would run but worth a consideration.
Old April 28th, 2014, 12:42 PM
more than that and then they would likely need to be painted to match.
Old April 28th, 2014, 01:40 PM
Brad's truck is white, so he could probably get away with a set of white NTO doors. I don't know if the whites would match though.
ac, factory, window, windows
Merc 300TD powered Disco 1 on ebay (not mine) hillstrubl The Flea Market 13 October 16th, 2011 10:35 PM
SIIa 109 Chevy powered. phoenix37 The Flea Market 0 August 18th, 2011 01:51 PM
Powered sub and amp single modulation of volume dmarchand Defender Technical Discussions 3 June 15th, 2011 09:49 AM
4.6 powered 97 D90s ECR Defender Technical Discussions 66 March 24th, 2008 10:30 PM
Power Windows (was: Leccy Windows!!!!!) P1CR Defender Technical Discussions 21 February 28th, 2004 01:14 PM
