Power Window Wiring - Defender Source
Old December 17th, 2015, 06:45 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Power Window Wiring
Does anyone have a how to when it comes to wiring a set of doors with power windows to my defender? I have a td5 dash so I would like to use the stock PW switches... I am not great with wiring.
Legend in My Own Mind.
Old December 17th, 2015, 07:11 AM
BlackField's Avatar
BlackField
Oscar
D110
Same boat as you. I have the Spal Deluxe set. I made a mistake thinking the Discovery and Defender Window switches are the same. They aren't. Definitely need the 5 pin defender switches. They just flip flop polarity. Makes for an easy two wire run to the motors.
Are you using oem hardware or something like Spal?
Old December 17th, 2015, 09:11 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I'm using Stock rover doors w power windows
Old December 17th, 2015, 09:35 AM
BlackField's Avatar
BlackField
Oscar
D110
That should be easy-pessy then.
So you just need to decode the 6 (edit) pin connectors then. I think I have it saved somewhere.
Is there a loom on the doors?
Old December 17th, 2015, 09:56 AM
BlackField's Avatar
BlackField
Oscar
D110
YUF101521LNF
1- Ground
2- Fused power source
3- to Lift Motor (Blue loom wire)
4- to Lift Motor (Red loom wire)
5- ? not used
6- Illum
Old December 17th, 2015, 10:23 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Ok. That's easy... So direct power can be brought right to the switch. Should I do something like a 15amp fused direct feed then just out to the door with a small harness?
------ Follow up post added December 17th, 2015 10:23 AM ------
Also, where do you get the plugs for the switches?
Old December 17th, 2015, 10:34 AM
BlackField's Avatar
BlackField
Oscar
D110
This shows the switches directly powering the lift motors via 20 AMP fuses:
Ebay for the connectors? Im sure PaulMC has a lead on them too (the AMP connector comes apart with a paper clip btw):
02 5 Land Rover Front Window Lift Switch Discovery Freelander YUF101521LNF | eBay
I'm not sure how the door harness looks. Running two wires per switch to the respective door. Then tap into the door harness if you have one, or direct to the motor if you don't would be my guess.
Old December 17th, 2015, 07:51 PM
carlosz's Avatar
carlosz
Carlos
Use a 30 amp relay in that system. Visit the 12 volt.com for wiring help. And tips...
the truck ran like a "raped ape"
A fussy warm weather creature...
Old December 17th, 2015, 08:02 PM
fun part is fishing the wires down through the bulkhead door post. The power windows aren't so bad, its when you add the additional for central locking things get hateful.
Old December 19th, 2015, 10:22 AM
PaulMc's Avatar
PaulMc
Paul McConnell
1989 110 2.5 Turbo-Diesel
They're not on eBay - but, I do have the White 6-way connectors for the YUF101521LNF electric window switches -
YUF101521LNF are used in Defender (from 2002), Discovery-2, and Freelander-1
Early Discovery-2 and Freelander-1 used YUF101520LNF, which has been superceded by YUF101521LNF which, I believe, has heavier duty contacts (the earlier switches would burn their contacts).
I can also supply the connectors to connect to the front door harnesses, for both electric windows and central locking -
PM me for details.
Paul.
1989 Arles Blue 2.5TD 110 Hardtop
1999 Epsom Green Discovery II 4.0 V8i 'XS'
Old December 19th, 2015, 10:38 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Paul. You will have mail shortly
Old February 2nd, 2016, 07:39 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Paul. What happened? Haven't heard from you.
Old February 18th, 2016, 09:37 PM
What motor/mechanisms are you guys using?
Old February 18th, 2016, 09:54 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I just finished installing 4 power window motors on my 110. Really easy once you figure out the first one. I used the SPAL deluxe kit (2), and their 7 switch wiring harness. I ended up just installing 4 switches in the dash, but have provisions for middle row door switches later. The biggest PITA is the running the wiring harness to the center dash, but the wiring kit has everything you need, even if you decide to use other switches.
ID:	142729   Click image for larger version
Semper Fi!
Old February 18th, 2016, 11:07 PM
bjf's Avatar
bjf
barry f
94 ST #395
Originally Posted by Wolf Fabrication View Post
I just finished installing 4 power window motors on my 110. Really easy once you figure out the first one. I used the SPAL deluxe kit (2), and their 7 switch wiring harness. I ended up just installing 4 switches in the dash, but have provisions for rear door switches later. The biggest PITA is the running the wiring harness to the center dash, but the wiring kit has everything you need, even if you decide to use other switches.
Any pics of the switches?
Old February 18th, 2016, 11:08 PM
Thanks. I'll have to order up a set.
Old February 18th, 2016, 11:34 PM
Wolf Fabrication
Sterling Archer
'08 D3
Bottom row on the center dash.
Semper Fi!
Old February 18th, 2016, 11:50 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Man Dave, I'm not going to recognize that truck when you're done with it!
Old February 18th, 2016, 11:58 PM
Old July 21st, 2016, 01:42 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Need to get this done. Paul where are you? Sent you multiple emails
window, wiring
Power window wiring TDI Guy Defender Technical Discussions 3 June 22nd, 2015 06:46 AM
Power window installation question tgraham Defender Technical Discussions 10 March 5th, 2013 05:38 PM
Switch/Wiring Question: Stereo Ignition Power Override nimbusnic Defender Technical Discussions 3 June 30th, 2008 01:05 AM
Winch/Power Wiring Opinion Wolf Fabrication Defender Technical Discussions 20 June 4th, 2008 10:55 PM
Power Window install kellymoe Misc. Chit-Chat 6 October 6th, 2005 11:18 AM
