Power stering fliud ??? - Defender Source
Old July 23rd, 2004, 12:53 PM
Vadim
vadim
95 D90
Question Power stering fliud ???
Anybody know what type of power stering fliud I can put in 95 D90???
Thank you in advance.Vadim
Old July 23rd, 2004, 12:57 PM
The book says ATF type F (Automatic Trans fluid).
Old July 23rd, 2004, 01:49 PM
Vadim
vadim
95 D90
Thank You Mike.
Old July 23rd, 2004, 02:12 PM
No problem!
Old July 23rd, 2004, 05:01 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
Aren't there different types of ATF? The manual for 97's specifies Mercon / Dexron III.
Old July 23rd, 2004, 10:39 PM
Yep! My 94 manual says ATF type F. I think any good quality brand would be fine.
Old July 23rd, 2004, 11:44 PM
They made it the same as the trans. 94s (maybe 95s too?) speced type F ATF for some reason but Dextron III works the same.
It does not matter. If your box is not leaking now, and you have a few dollars you might want to switch to the new fluid LR has. It is clear and seems to have less leaks than ATF in my limited experience with it.
Ron
Old July 28th, 2004, 03:53 AM
Vadim
vadim
95 D90
Thank you
Loss of power Leadfoot Defender Technical Discussions 4 January 28th, 2005 03:36 PM
Power Radio Antenna Kimos Defender Technical Discussions 0 October 21st, 2004 08:45 PM
Power Windows (was: Leccy Windows!!!!!) P1CR Defender Technical Discussions 21 February 28th, 2004 01:14 PM
