Power Steering Time - Defender Source
Old October 19th, 2014, 02:43 AM
spammer
Samdford Wallace
95 RRC LWB / 86 Tithnous
Power Steering Time
Just got back from a 2k mile trip in the Defender. Enjoyed it quite a bit but one thing I realized is that manual steering has no place in rock crawling. Steering wheel would whip around. Lucky I didn't break my wrist! So it is time to add power steering to my 2.5 LHD.
Are there any shops in the Bay Area that would know how to do this? I don't mind wrenching but I hate working on steering boxes in rovers.
I pulled this from another thread, and have some questions about parts:
- power steering box - I've read Meridian are good but huge core. Other options? Used boxes all leak which I'll pass on.
- power steering pump from n/a or TD defender - Can this be from a Classic or D1?
- power steering reservoir - Easy
- the bracket to connect the pump to the engine - No clue
- power steering belt - Should be easy
- crank pulley - 3 belt pulley, right? Should be able to track this down
- lines - Normal lines from Atlantic British, right?
Would love some suggestions for those of you that have done this conversion.
Old October 19th, 2014, 03:18 AM
When I broke my D1 pulled the box etc from that and installed in my 90 build. Don't know how much a recycling place would charge for one v cost of Meridian core charge.
You'll have to do some legwork here to figure out these two choices.
Old October 19th, 2014, 11:24 AM
spammer
Samdford Wallace
So all parts are the same as a D1? I thought for sure some parts were different, like the pully? Looks like I'll be hitting a pick n pull soon.
Old October 22nd, 2014, 06:09 PM
spammer
Samdford Wallace
Any idea how to locate the pump and or the bracket on how to mount it to the engine? Surely some of you have done this conversion.
Talked to a local "expert" shop who had no idea how to pull this off which surprised me.
Old October 22nd, 2014, 06:23 PM
I would just buy a new pump. That way you know it is good. They are not that expensive.
The Disco 1 one and later 200TDI---- http://www.lrseries.com/shop/product...RING-PUMP.html
Earlier 2.5NA/200TDI - http://www.lrseries.com/shop/product...-ASSEMBLY.html
The hard part will be the bracket, which you will need to find out of the UK. ETC8854 Costly as hell new. Need to find a wreckers...
Old October 22nd, 2014, 06:28 PM
jafir's Avatar
jafir
Jafir Elkurd
I bought my pump, bracket, reservoir, and some hoses from a user on the board. I had to get a pulley and a couple of hoses from the UK, but I think there are some people stocking it now. Rovah farm I think has them. I got a used disco steering box for $20 from the u-pull it yard.
By the time it was all said and done with most of the hoses new and the new pulley, I was probably into it for $400, but it's probably the best upgrade I've done so far.
The 3 groove pulley requires you to use a power steering belt for a vehicle with a/c
The parts are readily available, so i'm not clear why there is any confusion. Exploded views of the parts along with the part numbers are all over the web.
http://www.landroverweb.com/Pdf-file..._Catalogue.pdf
Every Land Rover parts diagram on earth here: lrparts.ru
Old March 21st, 2016, 08:13 PM
ben little's Avatar
ben little
ben little
1986 ex-MOD 110
Thread revival.
I have what I thought was a complete 'kit' for adding PS to my 2.5na turd.
Pump
Bracket
Box
Reservoir
Hoses
3 groove pulley
Tensioner...?
I went to install the belt... Do you really have to remove a pulley to add a belt? If not, I would think there is a tensioner involved. I've messaged a bit with another board member who added the tensioner from a RRC (ETC6148 and ETC6159). I mean, it makes sense... But I've only heard of this one instance of a tensioner being added. Anyone else done this?
Old March 21st, 2016, 09:13 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Don't know if it is normal procedure but, I have to loosen the bolts that holds the power steering pump to it's tensioner in order to take on/off the belt. Might be able with a pry bar by stretching the belt up to a point, but sometimes, it just don't feel right.
Might have a mix match of pump/holder/pulley/tensioner/belt
Hey,
I live with it...
Time Zones and Time? whitelandy33 Support & Suggestions 6 December 8th, 2009 04:31 PM
Time time has come to name my Defender Hans Misc. Chit-Chat 14 February 8th, 2005 08:54 PM
