Power Steering Question - Defender Source
Old May 27th, 2008, 10:57 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Well I managed to change my starter. Not that bad once I figured out my approach. But while I was under there I noticed that he power steering hose was cracked and leaking pretty good. So I removed it and replaced the hoes on either end of the pipe. Now I have no PS. What gives? Do I have an air lock? What could make a perfectly working PS system not work after replacing the hoses?
Old May 28th, 2008, 08:14 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Did you bleed it? The bleed screw is on top of the housing. other than that, there really is no reason for the lack of PS that I know of.
Old May 28th, 2008, 09:44 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Umm, apparently not well enough.
I did it again and all is well
RHD Power Steering Box.. TDI Guy For Sale - Parts 5 February 7th, 2006 10:42 AM
Power Steering Fluid Reservior fleabus Defender Technical Discussions 3 July 22nd, 2005 10:39 AM
