Power steering pumps? - Defender Source
Old August 16th, 2009, 05:14 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
I think I need a new pump. Does not squeal just hardto turn at rest. Is there any difference in the ZF compared to the Cardone? New or rebuilt? Where isthe best place for the money to get one?
Old August 16th, 2009, 05:40 PM
Did you try bleeding the box first?
Old August 16th, 2009, 05:43 PM
ive tried two, Ive bled replaced lines still whines like a SOB. Must be something in the swivels.
Old August 17th, 2009, 01:22 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
Bled the pump a couple months ago when I put a used pump on it then.
Old August 17th, 2009, 01:29 PM
I am not sure what would cause them to whine other than air. Ive driven a number of Rovers some with high miles others with not so high miles. I have never heard one whine. Could there be something inside of the actual steering box causing the pump to work harder? I am not sure what to do short of replacing the pump again.
Old August 17th, 2009, 01:37 PM
Do you have the lines on right?
Old August 17th, 2009, 01:40 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I have a rover pump in the garage that was on for just a few months until a diesel conversion. I'll check the numbers on it to see if you can use it.
Old August 17th, 2009, 02:57 PM
I think so, look the same as on the Defender which have never been touched. 0 leaks from the system.
Old August 17th, 2009, 10:18 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
That would be great let me know. thanks
RHD Power Steering Box.. TDI Guy For Sale - Parts 5 February 7th, 2006 10:42 AM
Power Steering Fluid Reservior fleabus Defender Technical Discussions 3 July 22nd, 2005 10:39 AM
