Power Steering Pump Plunger Orientation - Defender Source
Old July 30th, 2012, 09:24 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
On a 3.9L RRC power steering pump, I had to unthread the larger outlet fitting to get the high pressure line off and the little spring loaded plunger shot out. Anyone know which way it goes back in? It fits either way
Semper Fi!
Old July 30th, 2012, 03:58 PM
Wolf Fabrication
Sterling Archer
'08 D3
So, which way does it go back in???
Semper Fi!
Old July 30th, 2012, 04:03 PM
Wolf Fabrication
Sterling Archer
'08 D3
For posterity, it goes this way. I checked an old pump I had on hand....
Semper Fi!
Old July 30th, 2012, 04:30 PM
I'm assuming the pump isn't in the most inconvenient location on a RRC as it is on the D90?
Old July 30th, 2012, 04:48 PM
its in the same place
Old July 30th, 2012, 06:24 PM
Wolf Fabrication
Sterling Archer
'08 D3
Only tiny leprechauns can get in there to fix it.
Semper Fi!
Old July 30th, 2012, 07:15 PM
Before you let them loose on you truck, make sure you properly lubricate them with Guinness.
D90 Power steering PUMP WhiteD90 Wanted 1 February 1st, 2005 12:09 PM
Vendor for Power Steering Pump Pulley wheel ? norros Defender Technical Discussions 0 January 19th, 2005 04:12 PM
