power steering pump noise - Defender Source
Old October 27th, 2008, 12:08 PM
Before I go buy a replacement pump, I thought I'd see what you folks had to say about this.
My power steering pump (in a '94 D90 but is from a '94 Disco I with serpentine setup) started making a noise right before MAR. It's a pretty loud scream which goes away after a few minutes - not sure if it's because the fluid warms up or turning the wheel lock to lock helps it. I tried to bleed the system at the gearbox but saw no air and didn't seem to help. The system was working fine for a few months after swapping out the steering box.
I have the small black reservoir. Doug said it may have a filter on the bottom that could be clogged, but I haven't pulled it to verify yet.
Any ideas?
thanks,
charles
Old October 27th, 2008, 12:52 PM
Muscat
Mark B
2002 90 wreck
Charles,
I just checked a couple of spare reservoirs that I have. Neither of them have filters at the fluid outlet. There should be a removable fine mesh filter in the filler neck.
Every power steering box that squealed on me was caused by low fluid levels - the noise disappeared after filling up and bleeding the system. IIRC, you can bleed the system by turning the steering wheel fully left and then fully right, followed by replenishing the reservoir to the correct level. The manual warns against holding the wheel against the stop for extended time (30s) while doing this, but I can't recall why just now. Something about overheating or over-pressurising the fluid.
Mark
__________________________________________________ _______________
1982 LHD RRC - gone. 1986 LHD 110 (300tdi auto) - gone. 1995 Disco 1 - still going. 1996 Disco 1 - scrapped. 2002 90SV build up (300tdi auto) - in progress...
Old October 27th, 2008, 01:39 PM
Thanks Mark
Yes my reservoir has the removable one in the neck. The levels are fine and I did turn it lock to lock a few times before. I'll give it a few more tries though, thanks.
Oh, if it helps, the noise goes away at full lock.
charles
Old October 27th, 2008, 01:45 PM
I still think you are getting air in there somehow. Did you recheck all the connections?
Old October 27th, 2008, 01:56 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Would it means that if the cap of the reservoir is removed and engine turned off, some fluid should drip out on that connection?
Is is possible that one of the hoses is kinked/plugged (somehow)?
Charles, do you have some spare (old?) pipes you could try to use?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 27th, 2008, 02:01 PM
Ron, wouldn't air getting in somewhere mean I'd have a leak somewhere too? I'll go double check a later this afternoon but I don't believe I have any leaks.
No other hoses to try, although it's on my todo list to rebuild them as a precautionary measure.
charles
Old October 27th, 2008, 04:30 PM
I think Ron nailed. I checked while it was running and the low pressure line going into the pump was partially collapsed near the pump. I could squeeze the hose to change the collapsed side and hear what sounded like air sucking in as I did it. I'll replace the hose and report back.
thanks guys!
charles
Old October 27th, 2008, 04:53 PM
Playing with the 90 after spending 4 days away from home with the 110....carefull you will end up single like me
Old October 27th, 2008, 06:11 PM
LOL. It was just a quick peek.
Power Steering Pump dimcon Defender Technical Discussions 11 April 9th, 2007 08:34 PM
D90 Power steering PUMP WhiteD90 Wanted 1 February 1st, 2005 12:09 PM
Vendor for Power Steering Pump Pulley wheel ? norros Defender Technical Discussions 0 January 19th, 2005 04:12 PM
