power steering pump mounting brackets - Defender Source
Old November 14th, 2010, 12:08 AM
punter
1966 Series IIA
Does anyone have a good picture of how the power steering pump mounts in an early Defender?
I took copius photos during disassembly of my engine, but my hard drive crashed and I lost almost all of the photos.
I remember how most everything went together (alternator mounting assembly is already set up)... but I cannot, for the life of me, remember how the power steering pump mounted in. I'm sitting here staring at a pile of little bracket parts, nuts and bolts and I'm a little lost.
Any help would be greatly appreciated.
Cheers,
Old November 14th, 2010, 12:22 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
If yours is a 3.5 v8 rhd this may help. Image 52, 53, 75. It has white tissue stuck in one of the port
http://mudsux.multiply.com/photos/al...GINE_REINSTALL
Also here:
http://mudsux.multiply.com/photos/al...atorair_filter
MUDSUX
Old November 14th, 2010, 10:27 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
If that doesn't help I can get better/closer pics if you want.
MUDSUX
Old November 14th, 2010, 05:05 PM
punter
1966 Series IIA
Yep, that helps a lot... now I know why everything looked so foreign to me.
I took my PSP to a hydraulic shop to have it rebuilt a while back (because it was leaking) and it appears that the shop put the mounting plate(s) back on in the wrong orientation.
Would you please confirm for me a few things before I take this thing apart and fix it?
While looking at photo #52, we'll call the union bolt the top (12:00 position) and where the white tissue is hanging out the right side (3:00 positon)...
1.) The mounting plate on the front of the PSP has two tangs. It appears that the longer of the two tangs is at the bottom (6:00 poistion), opposite the union bolt... and the shorter of the two tangs is on the left side (9:00 position). Is that correct?
2.) The mounting bracket on the rear is not visible in any of the pictures, but it has one tang. I believe that it bolts into one of the tapped holes on the drivers side head (the lower, innermost I believe). Can you please conform for me in which direction the rear mounting bracket tang is supposed to be oriented (it looks to be the left side (9:00 position)?
Thanks for your help... this is saving me a lot of time and frustration.
Cheers,.
Old November 14th, 2010, 07:19 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Hey Scott, I think pictures will better help you. I took some more for you. I have the engine back in the truck so a lot of things were in the way but I hope this helps. The last 2 pics is from the bottom looking up. More pics here:
http://mudsux.multiply.com/photos/album/38
ID:	33087   Click image for larger version
ID:	33089   Click image for larger version
MUDSUX
Old November 15th, 2010, 08:49 AM
punter
1966 Series IIA
So THAT'S where that little tube/spacer goes!!!!
Yep, those pictures were perfect! I've got it completely. Thanks so much for your help!
Cheers,
Old November 15th, 2010, 07:31 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Cheers,
No worries, glad I could help.
MUDSUX
ac, bracket, mount, rack
Power Steering Pump dimcon Defender Technical Discussions 11 April 9th, 2007 08:34 PM
D90 Power steering PUMP WhiteD90 Wanted 1 February 1st, 2005 12:09 PM
Vendor for Power Steering Pump Pulley wheel ? norros Defender Technical Discussions 0 January 19th, 2005 04:12 PM
