Power Steering pump going out-- - Defender Source
Old November 2nd, 2015, 07:32 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
My power steering pump is failing--you can hear it, feel it and frothy fluid. Since my wife drives the D90, I want to replace sooner than later. I see that O'Reilly has a pump available with limited lifetime warranty for $200. MasterPro Power Steering 990-0474 - Power Steering Pump | O'Reilly Auto Parts Or I can pull one from UPull for about $30 (condition unknown). Didn't know if anyone had experience with the aftermarket pumps (this one from Mastercraft) or not?
BTW, if you see that I have a 94 and this pump is for a 97, it is because I switched front covers to get the crank driven oil pump which made me change the power steering pump...
Old November 2nd, 2015, 08:02 PM
I would rather have a good used one than a new aftermarket/reman. I don't think they are a common failure item. Also, I assume this is the case with Defender power steering reservoirs as it is with most Land Rovers, there is a metal screen in the reservoir that gets filled with metal from the pump. I'd recommend replacing the reservoir as well. Flush the power steering system with clean fluid before you replace the pump.
Old November 3rd, 2015, 12:16 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I've been going to auto salvage You-pull type lots for years. Just found out about www.car-part.com which links to local auto part recyclers that have already pulled the parts. Sort of cool when you don't want to pull hem yourselves (like when it's raining or snowing...). Thought I'd share. Found a place rather close that has what I need--in this case a used power steering pump for $35...Not bad...ill give that a go...
Old November 3rd, 2015, 04:45 AM
Meridian in California rebuilds them.
Old November 3rd, 2015, 06:50 AM
Originally Posted by Davis View Post
I've been going to auto salvage You-pull type lots for years. Just found out about Car-Part.com--Used Auto Parts Market which links to local auto part recyclers that have already pulled the parts. Sort of cool when you don't want to pull hem yourselves (like when it's raining or snowing...). Thought I'd share. Found a place rather close that has what I need--in this case a used power steering pump for $35...Not bad...ill give that a go...
Its not a ton of work to replace the pump, which is another reason to go used. I don't trust reman parts in most cases because I have seen so many problems with them at the dealership.
Old November 3rd, 2015, 08:55 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Meridian rebuilt my steering box, nothing but love for those guys. I know they are easy to replace, but still a pita when you have to do it outside in the dark after or before work and I want to get it done before Thursday. So hopefully pick it up today, put it in tomorrow morning...
Going to Vegas this Memorial day weekend, anyone else going? Neil McCauley Misc. Chit-Chat 7 May 30th, 2013 10:08 AM
power steering seems to be going out jayz Defender Technical Discussions 0 November 20th, 2012 11:56 AM
Power steering pump johnnyg15 Wanted 0 August 16th, 2006 05:32 PM
D90 Power steering PUMP WhiteD90 Wanted 1 February 1st, 2005 12:09 PM
Vendor for Power Steering Pump Pulley wheel ? norros Defender Technical Discussions 0 January 19th, 2005 04:12 PM
