Power Steering Pump Alternative crappy stock one - Defender Source
Old February 19th, 2014, 03:52 AM
CDeWan
Clay DeWan
5.3L beastie
This is another one of Nick' creations. It is mounting brackets to use a much higher flow power steering pump with reservoir instead of the remote resevoir set up that is in Defenders, Discos (1s) and Classics with a serpentine belt. This one is currently on a disco. I was over at Nick's house and one of his friends stopped by with Nick's creation on it so I snapped some pics if anyone is interested shoot him a pm.
so basically you ditch your old pump, lines, reservoir and stock mount and go with a new pump and a high pressure braided line and return line. I think the hoses are right from Summit and I don't think it matters where you get the pump but he has the info.
And sorry for the bad pic as it there is plenty of clearance between the pulley and upper radiator hose
ID:	89978   Click image for larger version
Name:	powersterring pump1.png
Name:	powersteering pump2.png
ID:	89980   Click image for larger version
Name:	powersterring pump3.png
Power Steering Pump for 97 D-90 Hammertime Wanted 2 December 27th, 2008 08:17 PM
Stock Steering Wheel dnewman9 Wanted 2 May 27th, 2004 01:57 AM
