Power Steering Not working - Defender Source
Old June 15th, 2016, 09:37 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
putting together a 300tdi with 50k miles on it. Installed the lines and a new steering box. Started it up and later noticed that the power steering is not working. fluid is topped off. Could the PS pump go bad? I never had a PS pump go bad so was just wondering if I should check anything or how to test things before ordering a new pump.
Legend in My Own Mind.
Old June 15th, 2016, 09:41 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Did you bleed the air out?
Old June 15th, 2016, 09:52 AM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Take the reservoir cap off, with car running and turn the wheel left and right and see if the fluid level drops. Keep topping off.
Old June 15th, 2016, 09:55 AM
I ordered a new pump recently. I recall they weren't too expensive from LR Direct. I wouldn't use a questionable pump considering the hell you'd have to go thru to replace one once the engine is in.
Old June 15th, 2016, 09:56 AM
Naplm00
Matthew
As these guys said, you may just have an air locked system. There is also a air bleed screw on top of some of the boxes
Old June 15th, 2016, 10:06 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have went lock to lock a shit load of times. No luck. In the past that's all I did but this time nothing.
Old June 15th, 2016, 10:18 AM
ZF pump is $89.34 shipped from LR Direct. I wouldnt wait a moment and order one up.
Old June 15th, 2016, 10:21 AM
Naplm00
Matthew
With the engine be running do you get any fluid movement in the reservoir? Also a messy test is to pull off the high pressure line at the box input and see if it sprays hard when Turing... This was you know it's not the box
Old June 15th, 2016, 10:33 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I'm mistake. It's a td5 not 300tdi. I don't see the td5 pump on LR direct
Old June 15th, 2016, 10:37 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Here you go...
Name:	Workshop Manual SRR652USWM A.jpg
Old June 15th, 2016, 12:12 PM
I'm probably wrong but it looks like the same pump to me. I have zero td5 experience.
Old June 16th, 2016, 09:23 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Td5 pump is different for sure. I had no time to to try to bleed it yesterday. I will try one more time then Im guessing the pump.
Old June 16th, 2016, 09:29 AM
Naplm00
Matthew
Hey I'm free if you want some help, pm me
Old June 17th, 2016, 07:58 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
No air in system. Im guessing the pump is bad. does not appear to have any pressure.
Old June 17th, 2016, 09:09 AM
Naplm00
Matthew
Bummer man, maybe go the s10 pump route? Crap that's for 300 unknown if it works on td5
Old June 17th, 2016, 10:30 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Td5 is a special pump it drives the water pump as well.
Old June 17th, 2016, 10:47 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
slightly loosen the pressure line and see if it leaks pressurized fluid.
Are you 100% sure you have the lines routed correctly?
RDavisinVA
Old June 29th, 2016, 03:54 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Ended up replacing the pump and all is well. Never had a faulty pump with no signs of failure.
Power Steering fluid not red but pink- Tyler Wirken Defender Technical Discussions 3 August 6th, 2012 10:51 PM
Speedometer not working mgrgpg Defender Technical Discussions 4 June 11th, 2009 07:27 PM
My headlights are not working woldd90 Defender Technical Discussions 13 December 2nd, 2005 10:49 AM
'95 Factory Radio Fade/Treble/Bass Button Not Working gamberik Defender Technical Discussions 1 March 30th, 2005 01:05 PM
Fan blower switch not working draaronr Defender Technical Discussions 3 August 24th, 2004 11:26 AM
