Power Steering Lines - Defender Source
Old October 7th, 2011, 06:31 PM
bjf's Avatar
bjf
barry f
94 ST #395
So I have isolated my power steering noise. It is the high line vibrating against the frame above the steering stabilizer. Only happens when I am at a stand still and turn left. Is this indicative of something? Lines aren't leaking and this is the only time I have an issue. The line seem to clamp to the frame so I am not sure how to fix it.
Old October 7th, 2011, 06:54 PM
specops1526's Avatar
specops1526
Beluga '97 90
Duct tape?
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old October 7th, 2011, 06:56 PM
bjf's Avatar
bjf
barry f
94 ST #395
Weak
Old October 7th, 2011, 07:13 PM
specops1526
Beluga '97 90
You're right, it probably will be too weak. Try gorilla glue. I heard that stuff is tough.
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old October 7th, 2011, 07:39 PM
bjf's Avatar
bjf
barry f
94 ST #395
Anyone have a real idea? Anyone who drives their truck
Old October 7th, 2011, 07:55 PM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
I had the same problem- turned out that the clamps had bent over time as well as the nutserts just did not hold the clamps tight enough to keep the hard PS lines from vibrating. I ended up tapping 2 new holes in the frame- clamps hold just fine now and I have not had a problem since.
Old October 7th, 2011, 08:26 PM
bjf's Avatar
bjf
barry f
94 ST #395
Did you buy new clamps too?
Thanks useful info
Old October 7th, 2011, 08:55 PM
do you own any tools other than a dildo? Maybe you should beat on it you could make it tighter.
Old October 7th, 2011, 11:21 PM
bjf's Avatar
bjf
barry f
94 ST #395
I just have a complete didlo set. Do you think the black double prong would be best for this or the pink small unit?
Dont be a dick. It was a Reasonable question. I will take a look tomorrow. For all I know it one bolt that needs to be tighten to fix it. Will keep you posted since you seem so interested.
Old October 8th, 2011, 12:31 AM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
I would make sure that is still the problem. Try getting a clamp (hand clamp) and clamping the line first and make sure this corrects it. If it doesn't then it could be something else.
Other option is get the lines replaced with "soft" hydraulic hose instead of "hard line".
Old October 8th, 2011, 12:56 AM
bjf's Avatar
bjf
barry f
94 ST #395
Well I shouldn't need to replace with soft unless everyone has this issue. I originally thought the pitman arm so I replaced it, then tie rod ends bit they are all good. Thought the box or pump but I got under the truck while someone turned the wheel and the noise is coming from the one line vibrating against the frame. I don't get why it only happens when I turn left though.
Old October 8th, 2011, 07:02 PM
bjf's Avatar
bjf
barry f
94 ST #395
Screwed around with it yesterday and it isn't the lines. Can't figure it out. It's a vibration in the wheel only turning left every other rotation of the wheel at stand still
------ Follow up post added October 8th, 2011 04:03 PM ------
Also jacked truck up and rocked wheels. Not coming from the hubs or tierods
Old October 8th, 2011, 08:37 PM
Can you better describe this vibration? Take a video perhaps?
Philip, go easy on him - he's come a long way since he first got his defender.
Originally Posted by pendy
I'm here for the D's
Old October 8th, 2011, 08:51 PM
bjf's Avatar
bjf
barry f
94 ST #395
It sounds like metal on metal hence I thought it was the line. Just turning left. Brian got it to do it by turning wheel full lock left and rocking the wheel. I can't seem to recreate that though
Old October 8th, 2011, 09:32 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
My bet is on the pump. Look around for a rebuilt one.
Old October 8th, 2011, 09:40 PM
bjf's Avatar
bjf
barry f
94 ST #395
Why the pump?
Old October 8th, 2011, 11:09 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Does it happen if you turn the wheel when the engine is off???
If your puny, skinny little girly arms can turn the wheel it might show the same noise which would rule out the pump.
My bet is the box itself. You are due for a new box anyways.
Old October 8th, 2011, 11:20 PM
bjf's Avatar
bjf
barry f
94 ST #395
Will try with car off but will assume my movement won't be as fluid but if it was the box you are right it should still make the noise or clunk.
My arms do fine. I have the perfect prison buold
Old October 8th, 2011, 11:36 PM
chris snell
Chris Snell
87 Ex-MOD 110
I bet on the pump because he saw his lines vibrate. I wonder if that pump is putting out consistent pressure.
That said, it's like the cooling system. Rebuild the whole fucking thing and you wont have any more problems for a while.
Old October 8th, 2011, 11:47 PM
bjf's Avatar
bjf
barry f
94 ST #395
Yeah I don't want to buy a box or lines though if it is the pump. I originally thought it was the lines vibrating against the frame but I removed the clamp and gave it space and the vibration is still in the wheel every other turn.
As for pumps I see a wide variety of prices. AB has it for 380 as does meriden for OEM I think but RN is 480 for genuine. Any thoughts?
As for the cooling system, I recored the radiator, replaced thermostat, hoses and so far it has been running great. So far no evidence of head gasket knock on wood
94 Power Steering Lines CDeWan Wanted 0 April 17th, 2011 02:08 AM
any issue having power steering lines rebuilt? defender1844 Smaller Projects 1 August 7th, 2008 03:21 PM
clamps to the power sterring lines mattdh Wanted 2 November 3rd, 2004 12:04 AM
