power steering leak - Defender Source
Old November 29th, 2012, 09:20 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
power steering leak
I am getting a drop or two a night. It looks like the hoses may be leaking at the reservoir. I know about the meridian boxes but I don't think it is the box based on the mess above the steering box.
Is there a way to remove the tank and change the hoses to a more durable solution? Or should I just clean up the hoses and replace the hose clamps with stainless ones?
I think Barry mentioned that sometimes the hoses can "weep". Thanks in advance.
Old November 29th, 2012, 09:59 AM
Naplm00
Matthew
Mine were doint the same thing. I just snipped off the old clamps and replaced the hoses with some rubber PS return hose from napa. New clamps and done
Old December 29th, 2013, 04:01 PM
mine is doing this - was the power steering hose just a stock item at napa? or do i need to match the inside diameter?
95' D90 - daily driver..
Old December 29th, 2013, 08:26 PM
Start by replacing the clamps.
Old December 30th, 2013, 12:35 AM
Just to be clear, it looks to be leaking from the bottom clamp area. I should snip off the existing clamp and just use a stainless hose clamp. Correct?
RHD Power Steering Box.. TDI Guy For Sale - Parts 5 February 7th, 2006 10:42 AM
Power Steering Fluid Reservior fleabus Defender Technical Discussions 3 July 22nd, 2005 10:39 AM
