Power Steering inconsistent - Defender Source
Old January 25th, 2014, 04:42 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
So, maybe its the cold weather doing a number on old seals/o-rings, but my power steering (RHD D110) developed an inconsistent assist pattern over the past week.
Starts out a bit stiff (but still has some assist), then after 1/2 turn of the wheel the assist increases and then it becomes less again after another 1/2 turn or so.
The reservior is full and I didn't see any leaks along any of the lines and the pump appears fine (no squealing or other noises), so I'm focusing on the PS box itself.
Is there a wear item (o-ring kit, bushing kit or something) that can be replaced in-situ, or should I be looking for a replacement box?
did a search and found a thread within a thread on the box replacement in an older Tjfslaughter thread: http://forums.lr4x4.com/index.php?showtopic=16765 but that doesn't really help me diagnose the problem, only the replacement.
I would imagine it wouldn't be too hard to find a RHD steering box around with all of the conversions that have been done over the years, but I'd like to start with diagnosing it and perhaps refurbishing what I have first.
Old January 25th, 2014, 07:14 PM
Jackie Treehorn
A
1985 (legitimately)
Yes, the pump and belt look okay.
I imagine that if the pump was on the way out or gone, there would be no assistance whatsoever, so again correct me if I'm wrong, but I'm looking at the box as suspect.
Old January 25th, 2014, 10:58 PM
Air bubble. Try bleeding it. There is a nipple on the top of the box.
Sometimes they go bad internally and do that, but I would start with the easy path.
Old January 25th, 2014, 11:32 PM
Jackie Treehorn
A
1985 (legitimately)
Awesome, thanks Ron. I'll start there tomorrow.
Is it fussy with what type of PS fluid?
Old January 26th, 2014, 02:26 AM
Originally Posted by Jackie Treehorn View Post
Awesome, thanks Ron. I'll start there tomorrow. Is it fussy with what type of PS fluid?
Cheap dextron mercon ATF is what it takes.
Old January 26th, 2014, 07:16 PM
Jackie Treehorn
A
1985 (legitimately)
Well, I tried bleeding and it didn't improve, but it was 10 degrees outside so I'll try it again to make sure I didn't cut any corners. I did notice that the fluid in the reservoir appeared a little "frothy", but that could be because I went through a few full opposite lock cycles .
I just don't see how it could be the pump. I mean if the pump provides pressure it would probably be consistent pressure rather than in "waves", at least based on my understanding of how hydraulic pumps operate.
Now, if the box had a worn component like a worm screw or someone, that would seem like it could cause the "on/off" feel I'm talking about....maybe?
I just would rather know with more certainty before swapping the box out.
Old January 26th, 2014, 08:25 PM
Could be a leak in a line, but I would guess the box is toast if bleeding did not help. I am out of ideas.
Old January 26th, 2014, 10:41 PM
Jackie Treehorn
A
1985 (legitimately)
Yeah, I'm going to drive as-is until the weather gets better or I can schedule some time in a warm garage. I haven't seen any fluid leaking so I would guess its a leak but I should have a better look.
I should probably start looking for a box just in case.
RHD Power Steering Box.. TDI Guy For Sale - Parts 5 February 7th, 2006 10:42 AM
Power Steering Fluid Reservior fleabus Defender Technical Discussions 3 July 22nd, 2005 10:39 AM
