power steering hose renewal - Defender Source
Old April 27th, 2010, 10:23 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Hey everyone,
Looks like my power steering hose has given up. After 27 years, it's cracked and seeping fluid. Can anyone tell me if it's possible to renew these? The metal tube and all banjo connections are good. Just the rubber is cracked. I cannot find replacement for a 1983 3.5 V8 RHD anywhere. I was thinking of just renewing the rubber hose myself. Is this hard to do? Thanks in advance.
MUDSUX
Old April 27th, 2010, 10:46 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Best bet is to pull it out, take it to a hydraulic shop, and have them put in new rubber sections.
-Hans
My oil line fix
My 100k stopped odometer fix
Old April 27th, 2010, 10:48 AM
Any hydraulic shop should be able to do it. On LHD trucks the job is made 100x easier by the updated hose that has an additional rubber section so you can actually fit it without bending the snot out of it. Should not be an issue on a RHD truck as the box is on the same side as the res. I am shocked that you can't find the hose though. RN should be able to get it or check lrseries or someone.
Old April 27th, 2010, 11:56 AM
Due to time constraints to make it to the MAR, I had a hose made up for my 90. We went to a Parker hydraulic store and they were able to make the hose but I had to cut the old ferrules away. For this used a dremel being very careful not to cut into the metal pipe. We then returned with the hose still assembled, but the old ferrules removed. Remember if you do this that some applications the hose ends need to be oriented a certain way so that the hose is not twisted when installed. If that is the case with your setup make sure you communicate that to the hose assembler in a way that they can understand and not fawk it up. Also they were somewhat reluctant when I said it was a power steering hose. Not sure why, but they did it anyway, works great, probably better than the factory junk and cheaper too. Though I did have to spend the better part of a day to get it done. YMMV...
Old April 27th, 2010, 05:50 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Thanks guys. So no chance of doing it at home with hand tools? Will have to find a hydraulic shop in Orlando.
MUDSUX
Old April 27th, 2010, 05:58 PM
If it is the low pressure ones you can just hose clamp them (at least I did and it was "ron good"), high pressure ones, no way.
Seriously, just order new ones. I think it was like $125 for all of them.
Here is one for 8ukp
http://www.lrseries.com/shop/product...%20hose&page=3
Power Steering Hose Replacement CDeWan Defender Technical Discussions 1 January 20th, 2009 09:31 PM
RHD Power Steering Box.. TDI Guy For Sale - Parts 5 February 7th, 2006 10:42 AM
Power Steering Fluid Reservior fleabus Defender Technical Discussions 3 July 22nd, 2005 10:39 AM
