Power steering fluid for 1995 NAS D90 - Defender Source
Old April 19th, 2015, 02:07 PM
Grover's Avatar
Grover
What are guys using? The workshop manual calls for AFT type F, AB says to use DEXRON 3...
I can't find either locally, only DEX 4...
This is for a 1995 NAS D90
Cheers...
Old April 19th, 2015, 02:39 PM
Ive been using valvoline maxlife in three land rovers fwiw
Old April 23rd, 2015, 09:24 AM
Grover's Avatar
Grover
Question
Valvoline Maxlife ATF or power steering fluid?
Old April 23rd, 2015, 09:27 AM
I've been told it should be ATF ... I've run both.
Old April 23rd, 2015, 09:56 AM
Castrol type F should be available at Advance Auto, that's where I get mine from.
1995, 90, 95, d90, nas
Power Steering Fluid JohnsD90 Defender Technical Discussions 5 June 16th, 2009 11:33 PM
Power Steering Fluid Billakris Defender Technical Discussions 2 June 26th, 2007 05:09 PM
Power Steering Fluid Billakris Defender Technical Discussions 0 June 26th, 2007 03:50 PM
Power Steering Fluid Reservior fleabus Defender Technical Discussions 3 July 22nd, 2005 10:39 AM
» Defender Registry
KT
rkinsk
MIke's D90
usla1
Add your Defender
