Power Steering Fluid for 1988 110 Diesel - Defender Source
Old December 26th, 2014, 09:51 AM
Ben Dutton's Avatar
Ben Dutton
Ben Dutton
1988 Land Rover 110
Good morning,
I need to top up the power steering fluid on my 1988 110. Would Castrol Transmax DEX/MERC (which is a mineral based product) be a good product to use?
thank you,
Ben
Old December 26th, 2014, 10:05 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
I always used cheap ATF without any problems. I once tried specific power steering fluid but, too thick.
Old December 26th, 2014, 10:09 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Yes, DEX/MERC is essentially DEXRON-III, which is compatible with DEXRON-IID, which is the correct fluid.
Old December 26th, 2014, 03:36 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
I've been wondering about the effects of using power steering fluid instead of ATF.
Does it just make steering harder? Or is it a lubrication factor?
Black Rhino Lives Matter
Old December 26th, 2014, 06:03 PM
jafir's Avatar
jafir
Jafir Elkurd
My first rover, a 1996 D1, had a pretty massive power steering box leak when I bought it. I didn't know any better and the reservoir was mostly empty so I didn't notice the color difference, so I filled it up with power steering fluid. It worked fine until it leaked out again.
Old December 26th, 2014, 06:12 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
ATF works as it is designed to work in hydraulik mechanix!
110, diesel
Power Steering Fluid JohnsD90 Defender Technical Discussions 5 June 16th, 2009 11:33 PM
Power Steering Fluid Billakris Defender Technical Discussions 2 June 26th, 2007 05:09 PM
Power Steering Fluid Billakris Defender Technical Discussions 0 June 26th, 2007 03:50 PM
Power Steering Fluid Reservior fleabus Defender Technical Discussions 3 July 22nd, 2005 10:39 AM
