Power Steering fluid change?? - Defender Source
Old August 4th, 2011, 03:49 PM
Verner Berry's Avatar
Verner Berry
Verner Berry
97 D90
97 D90, trying to renew the power steering fluid.
Does anyone have any suggestions on how to do this?
I've searched the site with no luck, any thoughts would be greatly appreciated.
Old August 5th, 2011, 11:10 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Pull the hoses on the pump (or loosen the banjo bolts), gravity will drain the whole system (mostly), then refill. Mobile one makes synthetic, if you're interested. When you refill, be sure to crank the steering hard left & right to the stops several times. This will purge the air from the system.
Old August 5th, 2011, 11:33 AM
At idle open bleed screw on PS box close screw refill. Powerwash the rest of the day.
This is the messiest way to do this. Pull a line of the box as mentioned above. You can also use your wife's baster vacuum a little from the res. Refill and repeat.
Old August 5th, 2011, 03:04 PM
Verner Berry
Verner Berry
97 D90
Thanks for the replies. I ended up going the bleeder screw method, that was one messing job! Thanks again, VB
Power Steering Fluid Billakris Defender Technical Discussions 2 June 26th, 2007 05:09 PM
RHD Power Steering Box.. TDI Guy For Sale - Parts 5 February 7th, 2006 10:42 AM
Power Steering Fluid Reservior fleabus Defender Technical Discussions 3 July 22nd, 2005 10:39 AM
