Power Steering Box Centerline - Defender Source
Old May 5th, 2015, 08:32 AM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Replaced the drop arm last night and was following the book that said to set the centerline of the steering box, turn the wheel to right lock and then back off two turns.
I did this 3 times and all three times the wheel was sitting about 1:30, not 12.
My only thought is that at some point a PO did something and got the mark off.
Can I just unbolt the wheel, set it to center and adjust the tie-rods to get it all back to square or should the wheel be pointing like that?
Many thanks for the help.
Nick
Old May 5th, 2015, 09:04 AM
You need to find the center of the box. Turn from lock to lock and count the turns exactly. Then find the middle position. Don't just use 2 turns and assume 4 turns lock to lock. Make sure the tie rod is not connected when doing this. If the steering wheel is off, then pull and reposition. Fine tuning is with the tie-rod after driving.
Old May 5th, 2015, 10:04 AM
97-D90-736
Nick Vogel
Thanks John. Makes complete sense.
Old May 5th, 2015, 11:14 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Really?
Dont you mean drag link to adjust?
Rent my
Leaky power steering box Lindy Defender Technical Discussions 15 January 26th, 2009 04:31 PM
Power Steering Box Brim Wanted 2 May 4th, 2008 11:31 PM
Power Steering Box Retrofit Wanted 0 December 18th, 2006 09:19 PM
RHD Power Steering Box.. TDI Guy For Sale - Parts 5 February 7th, 2006 10:42 AM
