Just replaced a worn out 3 bolt power steering box with a new 4 bolt. To clarify for anyone else doing it Doug was dead on the only mod needed were two small adaptors to connect the old lines to the new box. After doing all the bushes plus the new steering box it drives like a dream. Was told some of the later boxes used a different bolt size mine were the same.
Bought the box and adapters from Britcar, if you do it order the lock tabs for the 4 bolts. It was night to day when I did mine. We did the other bushes front and rear as they were bad and it did improve things but still had way too much play made worse by the 2" lift.
Related Threads
Defender Source Forum
1M posts
24K members
Since 2003
