Power loss and popping! - Page 2 - Defender Source
Old May 27th, 2004, 02:56 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
41 lbs.
Old May 27th, 2004, 03:03 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
The best way to check fuel pressure is to pull the line and stare down the hose as you turn on the engine JK, sounds like the best fix is a TDi.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 27th, 2004, 03:06 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
Thanks for the replies guys. I'll work on that let you know what happens.
Old May 27th, 2004, 03:24 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
Originally Posted by Mike Hippert
Can you check the fuel pressure? Seems like your not getting enough fuel. Turn the ignition to on and listen to the fuel pump, how long does it stay on and how’s it sound?
So how long should it stay on when you turn the ignition on?
Old May 27th, 2004, 03:26 PM
Normally a couple seconds.
Old May 27th, 2004, 05:56 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
BAD CAM! lobes might be warn. Does it pop though the intake!
Old May 27th, 2004, 06:25 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
Really? that's not good. Yes it does pop through the intake.
I'm gonna buy a fuel pressure gage tomorrow and see if this is the problem first.
Old May 27th, 2004, 06:30 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
DO a compression test/ leak down test!
Old May 27th, 2004, 06:32 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
Ok, I will do that if the fuel pressure is fine.
P.S. Where can I get the tool to test the compression?
Old May 27th, 2004, 07:32 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Hmm, there's a lot of good advice provided here but it sounds like your extrapolator is wearing out. It happens when your Defender doesn't get enough panties and/or thongs hitting the windshield. To fix it you need to drive alone & quickly to Fort Lauderdale. Now, be careful that you don't run into the "Girls-Gone-Wild" film crew because that might result in panty overload and your D90 might perform too well and blow a head. Just peruse around town for a while until the D90 is in tip-top-shape and you can head back!
Seriously, If it's backfiring through the intake especially when you accelerate then chances are you need a new cam shaft Yousef.
DJ
Old May 27th, 2004, 07:38 PM
dnewman9's Avatar
dnewman9
Dennis Newman
*SOLD*Conniston 97 NAS 90
I agree that is exactly what my dads disco did when the fuel pump went out.
Dennis
Also, the exhaust got red hot as it was running VERY lean. Be carefull how long/hard you drive it untill you get it figured out.
Old May 27th, 2004, 09:57 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
A cam is not the end of the world! Think of all the fun you will have when you put a hot cam & a remap of your ecu! I know it is big bucks but better in your driveway that on some remote rock someplace. GOOD LUCK!
Peter
Old May 27th, 2004, 10:03 PM
Shane@EVS
Roverhybrids
I would check the timming, sounds retarded:D
Old May 28th, 2004, 08:43 AM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
Kinda sounds like a timming issue. Is your distributer loose? Also pull the dist. cap and see if anything looks funky, like carbon or metal flakes etc.
You just may have to go see your girlfriend Linda
--Benjamin Franklin
Old May 28th, 2004, 03:51 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
Hmmm, mine takes 10-15 seconds. Does that mean it's going south? These don't look fun to replace (97's don't have an access hatch in the floor).
Old May 28th, 2004, 04:11 PM
Well, I'll listen to mine when I start it and I thought it was faster but I may be wrong.
Old May 28th, 2004, 07:12 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
You can always make your own. I cut my tub last time and covered the whole with aluminum plate. If my problem is the fuel pump all I have to do is remove the rear seat and carpet and I'm in business
Old May 28th, 2004, 07:14 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
Dennis
That's exactly what my D90 did. I opened the hood and dang, that think was HOT. Let's hope it's the pump since I have a spare one in my garage.
Old May 30th, 2004, 01:24 AM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
IT'S ALIIVEEEEE! The problem was the sender hose in the fuel pump assembly. It was loose and couldn't build enough pressure. Went to pepboyz got 5/16" hose, clamps ($4). Put it together and the truck started right up, even faster than when it had the factory fuel pump. I am one happy person. Now need to start tackling the other problems.
Thanks for the help guys
Old May 30th, 2004, 01:51 AM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Lucky SOB! A $4 fix! That's got to be some kind of record Yousef! Good to know that it wasn't a cam though!
