power inverter question - Defender Source
Old June 9th, 2011, 11:28 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
I plan to put some plugs in the back of my cubby box for misc electronic stuff in my truck. I will be puting a dual battery set up in first but my question is there some kind of kit for this or is it something I can put together with stuff from my local electronics specialty store? And what is the pain in the ass factor on a project like this?
Old June 10th, 2011, 01:16 AM
Naplm00
Matthew
If your talking 12v cigarette plugs, get them from a marine supply. I got a rubber/stainless one from west marine for12. Also buy some inline water proof fuses.
Easy project
------ Follow up post added June 10th, 2011 01:18 AM ------
Edit, crap just realized you were talking inverters...but west mating sells types recepticles too
Old June 10th, 2011, 01:32 AM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
No I want to put actual electrical plugs for a computer or something that doesnt have a cigarette lighter adapter
Old June 10th, 2011, 02:00 AM
Chaucer
Will
93 110 | 97 90
No kit that I know of. It's all about trying to come up with a clever way to mount an inverter.
Old June 10th, 2011, 08:37 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Jason, I interpret your question about "kit" as relating to the dual battery install? The answer in that case is yes. National Luna, Hellroaring (my choice), a host of others. Most marine supply places sell isolators and the other bits you need to do multi-battery installs as well.
You should be able to mount the inverter in the seatbox with the battery(s), which is ideal because you always want the wire run to the inverter to be as short as possible. The run coming out of the inverter can be longer with no issues. Since the seatbox hasn't got the best ventilation, either get an inverter with an integral cooling fan, or mount a little 12v computer fan to move some air over it so it won't overheat.
I agree on getting the mains outlets from a marine supplier, they'll be more appropriate and durable for use in the truck. For wiring out of the converter just use an outdoor extension cord, cut to length and wired to your mains outlets.
Tony
1984 110 "Smokey" (sold)
Old June 10th, 2011, 11:54 AM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
I am talking about the inverter. Is it just a box you run a fused line into and the go from the box to a mounted plug? I have seen some nice looking cubby box set ups that I would lime to copy in my truck. Do you just get an inverter at an auto parts place or do you have to order some special set up?
------ Follow up post added June 10th, 2011 11:02 AM ------
so I did a search on eBay and answered my own question. I was just wondering if there was any tricks or suggestions anyone had for installing one of these things. The internal fan was a great tip thanks Tony
Old June 11th, 2011, 12:23 AM
texrover's Avatar
texrover
Jason
Decent site (never bought anything from them):
http://www.theinverterstore.com/
Here's one with a 13' built in extension:
http://www.theinverterstore.com/the-...el=bct010009d#
If you want permanent (mounted) receptacles, you can order a socket assembly (see pic; outlet plug you can order for a Toyota Tacoma)
Or, as Tony mentioned, try a marine supply store:
http://www.defender.com/product.jsp?path=-1|328|299260|319691&id=1360492
http://www.defender.com/images/201672.jpg
There's probably tons of marine and camper forums you can google for more info, but if you keep the runs short, that's the safest option.
Name:	AC Plug Toyota Tacoma.jpg
ID:	39540   Click image for larger version
Old November 2nd, 2012, 04:34 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
Jason Z.,
Did you ever do this project? I really like the idea of a seatbox mounted inverter with a remote receptacle.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Switch/Wiring Question: Stereo Ignition Power Override nimbusnic Defender Technical Discussions 3 June 30th, 2008 01:05 AM
Power Steering Question mdmccallum Defender Technical Discussions 2 May 28th, 2008 09:44 PM
Loss of power Leadfoot Defender Technical Discussions 4 January 28th, 2005 03:36 PM
Power Windows (was: Leccy Windows!!!!!) P1CR Defender Technical Discussions 21 February 28th, 2004 01:14 PM
