Power Door Locks have a mind of their own - Defender Source
Old March 4th, 2012, 12:04 PM
D110
Jamie
1955 107
Recently the power door locks in my '97 D90SW have developed a mind of their own, especially when opening or closing a door (they lock, unlock and sometimes lock again without me touching the remote). I was wondering if anyone else had experienced this and how they went about troubleshooting. I'm guessing that there is a bad ground or a loose wire somewhere, but I'm not sure where to start looking. Any help/ suggestions would be appreciated.
Old March 4th, 2012, 02:59 PM
pipermalibu's Avatar
pipermalibu
Bryan Adams
97 D90
Do you know what door lock system you have installed?
Old March 4th, 2012, 04:53 PM
D110
Jamie
1955 107
I'm not sure, but I believe it originally came from the dealer with the power locks. I'm guessing that these were installed in the US by the dealers as an option and not the factory.
Old March 11th, 2012, 04:48 PM
D110
Jamie
1955 107
Feeling a bit stupid.... looked at my remote today which has "Viper" clearly stamped on it. Found a wire that had been cut and reconnected, but it hasn't solved the problem. Thinking I may just pull the panels off and take the whole power lock, alarm system out as it is driving me nuts.
Old March 12th, 2012, 09:11 PM
D110
Jamie
1955 107
Here's what I have found - The passenger side door will not lock or unlock with the remote or when I use the key in the driver's side door, but if I use the key in the passenger side door it will lock/unlock the drivers side as well. When I use the remote it will lock the driver's door, but when I go to unlock it, it unlocks for about 1 second and then locks it again.
I'm assuming the passenger side actuator is shot (couldn't find any bad connections) but could this be what is causing the unlocking then re-locking behavior on the driver's side?
I'm considering pulling the whole system out....
Old March 13th, 2012, 09:47 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
I had the exact same issue on my truck (the drivers door was the problem).
Basically a bushing broke and there was too much resistance on the upper rod and actual lock indicator (if that is what it is called). The lock sensed that it was being pushed down.
Take a look at all the lock levers and see if they are moving smoothly up and down, if there is one that is not that might be your problem. You will have to take the door card off and remove the lever and see if that fixes it.. Good Luck.
Old March 13th, 2012, 12:01 PM
D110
Jamie
1955 107
I'll give that a shot today - thanks!
door
Loss of power Leadfoot Defender Technical Discussions 4 January 28th, 2005 03:36 PM
Power Radio Antenna Kimos Defender Technical Discussions 0 October 21st, 2004 08:45 PM
Power Windows (was: Leccy Windows!!!!!) P1CR Defender Technical Discussions 21 February 28th, 2004 01:14 PM
