Possible Starter Issue - Defender Source
Old August 18th, 2006, 12:26 PM
Andrew Vick
Andrew Vick
95 D90
Starter was spinning very slowly in the morning, but gets better over the course of the day. Figured the battery was dying, so without testing it, replaced it.
Starter was even slower to turn this morning, so I figure that 1: I need to test the battery as it could be bad out of the box, 2: Check the connections on the starter.
I always saw starters go bad and just stop working, unless you got lucky and could knock some sense into them with a hammer. Do they go bad and slowly stop working?
Old August 18th, 2006, 12:33 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
I would test battery and ig good, then the alternator. If both good then check for drain in the system. I don't think the starters are a common failure problem. Never had one fail unless gear is stripped.
Old August 18th, 2006, 01:22 PM
Check the voltage at the starter, it should be within .2 volts or so of the voltage at the battery.
Old August 19th, 2006, 07:43 AM
Andrew Vick
Andrew Vick
95 D90
Will do this am. Thanks for the help.
start, starter
Starter issues on my D90 Rover- Girl Defender Technical Discussions 13 February 13th, 2010 10:59 PM
Wobbly distributor cap? and an update on my starter problem MiniGuy Defender Technical Discussions 6 January 10th, 2006 10:13 AM
Compatible starter motor question? MiniGuy Defender Technical Discussions 14 January 3rd, 2006 10:58 PM
Starter solution for TD D90? torque Defender Technical Discussions 0 April 30th, 2005 11:10 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
