Portal axles! - Defender Source
Old May 7th, 2004, 04:18 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
Portal axles!
If I had to put some under the 90, which one should I do?
Old May 19th, 2004, 03:04 PM
How did I miss this post? If you are staying with under 44s and a under 300hp I say 404 unimog if you are going with 52s then Unimog 1300s but if you stick with your 37" tires then the Volvo 303s should be good. When are ya gonna do it?
Old May 19th, 2004, 03:19 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
You going to be staying on the street or trailer?
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 19th, 2004, 05:57 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
WHY
Mike Hammond
Old May 19th, 2004, 06:03 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
WHY?! WHY!? Uh, maybe it's the 6 inch improvement in ground clearance. Thats like going from a 37in tire to a 49in tire! It could be the 1/2 reduction in drive train stress, or the lower gearing, or the elimination of adverse driveline angles from a big lift. Did I mention there damn tough? Your killig me Mike!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 19th, 2004, 06:16 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Thsi should give you an idea:
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 19th, 2004, 06:23 PM
mikeslandrover
Mike Hammond
Mike Hammond
Old May 19th, 2004, 11:53 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
Wow, how did you find this thread. I posted this thread long time ago but never came through. I thought maybe something was wrong with the website.
As for why, I don't know. I just like to try new stuff, sometimes I do it and some times I don't.
World traveler
Old May 20th, 2004, 12:10 AM
HMMM, I can't see how I missed it. It was posted between 2 threads I responded to. Maybe just a fluke?
Old May 20th, 2004, 09:40 AM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
Wow! I did some reading on the portal axles awhile back but never really seen them quite like the picture you took. That picture says a lot....Damn!!!! Are those 37s or 44s?
Glenn
Old May 20th, 2004, 10:29 AM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
I think they are the 40" rock spiders.
Hey David, is that a 9" mog hybrid?
World traveler
Old May 20th, 2004, 10:46 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
The tires are 40 in MT/r's. Those are mog 404 outers and 9in true High pinion. That is the best of both worlds. You can get r+p as low as 2.62, I believe, to keep the truck streetable. I want one of these things real bad. With 35 spline axles, that thing will handle 50in tires.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 20th, 2004, 10:56 AM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
Those portal boxes have some VERY low gearing huh?
I wonder if I can adjust my coil over hight to make it work with the mog 404's.
World traveler
Old May 20th, 2004, 11:21 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Depends on what height you are trying to get to. The gearing is very low. If you choose to make a mog9 you can get around it but if you use straight 404's you will be up in the 6 range. You need to run 44 in tires to pull it off on the street. Or regear your t-case. These things come with a 6in lift built in so if you stuck them under your rtuck right now you would be looking at a 9in lift give or take. Thats about the right hight for 42's. I do not know what height you are going for but when I set up my coil's up front, they sit about 1in below the top of the hood, are adjusted ALL the way down to minimum ride height and even have a short upper spring and I still have almost a 4in lift in the front. Good luck
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 20th, 2004, 11:35 AM
Dave Stop saying things like 42 and 404 and 6" of lift. Ugh I need a second Job so I can buy some 42s and 404s.
Old May 20th, 2004, 11:39 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
You and me both Mike. I want to build a rover tube buggy with these bad boys under it!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 20th, 2004, 05:07 PM
A 90 is probably not the best choice. Youd' want more wheelbase. Unless you like rolling aver backwards. I always thought a bobtailed 110 would work nice.
Old May 20th, 2004, 05:12 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I thought about this too, but I would much rather stretch a 90. Pull the rear tires back 10 inches and move the front forward 3 to give you a total wheel base of 107. I think 108 is the best in most situations but one inch won't matter. Then you could fit big old tires in there with a dovetailed front and rear truck. No that would be smoking!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 20th, 2004, 05:16 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
I thought about moving my axles but the rear gas tank limit me from doing that. I probably can move the rear 1.5" and the the front 2" but I don't think it's worth the trouble.
I agree with you John. If I end up doing a portal it won't be in my 90 frame, too short.
World traveler
Old May 20th, 2004, 05:57 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Yeah, for a couple inches there is no point. The front would be helpful though.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
axle
101 FC axles for sale Method PHX For Sale - Parts 18 March 24th, 2006 10:27 PM
Installing portal axles robisonservice Misc. Chit-Chat 18 February 21st, 2006 03:49 PM
35" MTR's, Wheels, Axles madcowdungbeetle For Sale - Parts 0 January 27th, 2006 07:28 PM
What kind of DC shafts and axles is GBR selling? cbass Defender Technical Discussions 12 July 19th, 2005 01:03 PM
GBR 4:10/ARB 3rds and Axles WhiteD90 For Sale - Parts 6 December 2nd, 2003 03:00 PM
