POR-15 the inside of the frame? - Defender Source
Old February 21st, 2011, 10:05 PM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
Since many frames rot from the inside out, I have been thinking about applying POR-15 on the inside of the frame (I have used it on the outside of the frame with good success). I realize one of the first hurdles would be how to prep it.... That said, I was thinking powerwashing it, but I have a feeling that would not be adequate... Anyways, I was thinking POR-15 could be applied via a spraying wand and a couple of coats could be a more lasting solution than other rust treatments. I know I may be totally out in left field with this, but any thoughts or suggestions?
Old February 22nd, 2011, 05:30 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Waxoyl.
The problem with your POR15 idea is you need a clean, grease and rust free (neutralized) surface. If you spray POR15 inside all you will do is cover up that stuff and the POR wont stick. You need a wax/parafin based product for enclosed frames.
Semper Fi!
Old February 22nd, 2011, 05:48 AM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
I agree with the Wolf. And a lot of hassle on an old frame that you can't see the inside of regardless.
See how long you actually hold on to the vehicle and you truly see signs of true rot. That may be years away and at that time, just get a galvanized frame and be done with it.
Old February 22nd, 2011, 10:26 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
POR-15 outside, Waxoil or similar inside
I sprayed stuff similar to Waxoil inside my frame a few months ago. I plan on doing this on a yearly basis. I did POR-15 the outside of the frame, but that does not seem as permanent as I thought it'd be. Rock rash will require touch up (likely not with POR-15).
MonLand
1995 D90 NAS
1996 Discovery NAS
Old February 22nd, 2011, 12:52 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
I've used this on the last couple of crossmember replacements as well as just spraying teh whole frame on a customer's S2A. No real measure of effectiveness, but it was easy to apply- comes with a rosebud tip on the end of the applicator hose so you can get 360* coverage.
http://www.eastwood.com/internal-fra...ay-nozzle.html
Email is
Same place, new dogs.
Old February 22nd, 2011, 01:14 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I bought some of this as well and plan to use it when it warms up a little. I have had good success over the years with Eastwood products and hope to have the same with this
Old February 24th, 2011, 03:48 PM
Naplm00
Matthew
Ziebart also offers a internal frame and cavity product and undercoating. Price I heard was reasonable
Old February 24th, 2011, 07:50 PM
NoVaKevin
Kevin
sold#1469
Im not sold on ziebart or even waxoyl if rust is already present. I like eastwoods or por15. Eastwoods is probably how I will go (maybe also waxoyl) in a few months after a good powerwashing and letting it dry.
From researching the topic, some say that por15 actually needs rust to bond to in order to stick for the long term and to be most effective, and others say it needs a clean surface, so I am not sure what it needs to be effective.
Old February 24th, 2011, 07:58 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Originally Posted by NoVaKevin View Post
.....some say that por15 actually needs rust to bond to in order to stick for the long term and to be most effective, and others say it needs a clean surface, so I am not sure what it needs to be effective.
I have used POR15 before. It needs a clean (grease/oil free) but rusty surface to bond well. Do not waste your time on a shiny smooth surface. It will just peel of in a few weeks. You gotta prep it well. Degreaser, metal ready, POR15, and maybe even an overcoat. Any exposure to UV and it will fade. Not important for inside the frame but in case you use it somewhere else.
MUDSUX
Old February 25th, 2011, 12:43 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
x2 coming from the jeep world. POR15 added many many years to my CJ's frame life, cleaned but with surface rust. Then a few topcoats of undercoating (after it had dried/cured)
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
How straight is a typical Defender frame? madcowdungbeetle Defender Technical Discussions 9 August 22nd, 2009 05:43 PM
Rear A-Arm Frame Brackets..etc TDI Guy Wanted 14 February 16th, 2006 09:15 AM
109 Galvanized Frame Coiler For Sale - Parts 1 December 29th, 2005 11:53 PM
95 Defender 90 frame and ST roll cage crobinson For Sale - Parts 6 November 24th, 2005 12:46 PM
looking for seat frame jcasteel Wanted 0 July 19th, 2005 09:55 AM
