por 15 in waxoly spray gun? - Defender Source
Old July 12th, 2010, 12:54 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Is it possible to use por 15 in the waxoyl spray guns. I'm thinking of using this first on the small amount of rust I have. I want to spray this inside the frame then do the waxoly over top.
Anyone ever done this?
Old July 12th, 2010, 01:46 PM
IME......POR-15 needs fairly serious prep to the surface if you want it to stick. Spraying it inside a frame will lead to itcoming off and providing a better spot for rust to form. I would suggest just using Waxoil on the inside. Leave the POR to area that are rusty and you can prep prperly.
Old July 12th, 2010, 02:06 PM
Campbell's Avatar
Campbell
Rich Campbell
thanks for the tip.
Can you think of any other type of converter?
Ospho?
Old July 12th, 2010, 02:20 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
John,
prep for the POR15 is just making sure there are no flakes and so forth...it needs a rusty surface to adhere to...it will not work over bare metal...
Old July 12th, 2010, 03:43 PM
Originally Posted by Campbell View Post
thanks for the tip.
Ospho?
POR-15 is NOT a converter. It is simply a coating that is meant to seal out moisture. If you want to convert, spray with phosphoric acid, then rinse with water.
POR-15 will stick to bare metal with the correct prep. It will not stick to paint without a primer, though.
Old July 12th, 2010, 09:42 PM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
I am a huge advocate of rust destroyer. It is a top quality rust converter and it is reasonably priced. They used to carry it Home Depot. Now, you can order it online at epaints.com I painted a float trailer with it and the paint/primer lasted 8 years with no rust through(I sold it after that). I also primed the entire frame on my last series lla with a pad and top coated with black polyurethane top coat machine paint(scatrust brand). Its great stuff and I like it better than por 15.
Doctors vs Gun owners! Departing90 Misc. Chit-Chat 3 June 20th, 2008 05:21 PM
Spray on mud from the UK Mark M Misc. Chit-Chat 4 June 14th, 2005 03:41 PM
OEM Land Rover Gun Box RFA Wanted 4 February 20th, 2005 09:14 PM
Line X / Spray In Liner ? rcmorgan540 Misc. Chit-Chat 10 June 1st, 2004 02:49 PM
rivnut gun mattdh Defender Technical Discussions 6 March 30th, 2004 06:46 PM
