pop! goes the turbo? 300TDI - Defender Source
Old May 3rd, 2015, 04:18 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I'm driving along the other night, minding my own business, when I go to accelerate from a stop and the truck is barely moving. RPMs are up but there's no umph. I look at the boost gauge and it's "0". Hmm.
Then, suddenly, it kicks in and all seems normal. I start to think about stuck boost diaphrams when suddenly I hear a noticable "pop!" noise. Now the motor is making a more... how to describe it, "mechanical", almost sewing-machine noise, and the boost never goes above 10 (used to go well past "11" and up to 15).
I drove it home. Casual inspection didn't show anything in the pressurized part of the intake that was ruptured, but it was dark. Oil pressure/temp/EGT seem normal.
The next day I drive up to Home Depot and see in my mirror a very large low-hanging fog behind me with a slightly bluish tint. I pull over, inspect and see occasional, but not constant, bursts of bluish-tinted smoke coming from the exhaust.
Thought:
Turbo oil seal broken (would explain the cloud) but what was the pop and why would this reduce boost?
Could something else have caused the seal to break?
I'm assuming either way it's a new turbo step #1.
Old May 3rd, 2015, 04:33 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Must have been an unusually clear night to see the moon and stars over the "comforting orange glow" of the Port of Los Angeles...
Old May 3rd, 2015, 05:43 PM
Almost sounds like a wastegate acting up. in my experience, when turbo seals go, there ain't no coming back. Boom done.
The pop sounds and total loss of boost and power you describes has happened to me before when my lower silicone hose ruptured at the clamp. you sure your pressure side hoses are all good to go and totally sealed?
Mark Kellgren
KM4BOR
Old May 29th, 2015, 03:21 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Well, as best as I could see and feel they look secure.. but the considerable cloud of smoke makes me think it's sucking a lot of oil from somewhere. If not through the oil seal on the shaft bearing then where?
Old May 29th, 2015, 03:28 PM
Could be a whole bunch of things other than the turbo. You need to investigate....
Old May 29th, 2015, 05:16 PM
ATX_D110's Avatar
ATX_D110
Victor
1985 RHD D110 (SOLD)
Same/similar experience with my 200Tdi a couple of times recently - Both times was hose issue (popping off at the clamp) all 90 degrees are about to get changed to silicon.
Old May 29th, 2015, 06:19 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Gotcha. I'll investigate further. Thanks...
Old May 31st, 2015, 06:36 AM
Ohlins's Avatar
Ohlins
Retired Weirdo
1986 Army 110
300tdi's have a typical problem of the lower intercooler hose delaminating on the inside.
This gives one of the symptoms you describe and is easily checked.
The engine will run but all power is zapped.
I'd check the lower hose to see if it's either slipped off or has gone to jelly.
All the best
200tdi Ex British Army 110 Hardtop 139142kms
2.286 Petrol Series 3 Lightweight 75,043kms
3.2DiD Pajero 266,000kms
Yamaha XTZ660Z Ténéré 58112kms
Gas Gas 300EC Ohlins Enduro Moto.
300tdi, tdi
Turbo Diesel or Diesel Turbo? Paul K Misc. Chit-Chat 11 April 11th, 2013 11:59 PM
Superwinch X-10 went "pop"...repair options PMKColorado Defender Technical Discussions 9 July 15th, 2010 10:23 AM
Disco II Driver window pop JohnsD90 Defender Technical Discussions 6 July 9th, 2009 06:39 PM
POP under my left foot when I hit the gas. wicks Defender Technical Discussions 11 September 30th, 2008 09:30 AM
Linkage - gear box shot ? My 1st time (pop!) paulb Defender Technical Discussions 10 January 21st, 2008 07:07 PM
