Poor Brakes - Master Cylinder ? - Defender Source
Old July 27th, 2012, 01:16 PM
kzack's Avatar
kzack
Keith Zack
none
1984 90 with 300tdi.
There seems to be no 'power assist' to the operation of the brakes. The actual braking and stopping is fine, but only happens at the bottom of the brake pedal stroke. The first 3/4 of depressing the pedal really doesn't do anything. If the pedal is pumped, it will build pressure.
I can not hear any hissing under the hood with the egine running or not running, pedal depressed or up. I removed the vacuum hose going to the brake booster and it had a lot of suction (though I didn't measure it and do not know what is normal). There are no leaks that I can find and there is no loss of fluid.
I'm wondering if the master cylinder has failed ? Is there a way to check it without removal ?
Thanks for any advise.
Keith
Drive the Best - Drive a Hammond
Old August 6th, 2012, 12:36 AM
michael67's Avatar
michael67
Michael White
110 Tdi
Make sure your rear drum brakes are properly adjusted - mine started doing what you describe when one of the rear adjusters failed.
Failing that, bleed the brakes and check for small leaks (dirt around brake line fittings).
brake, master
Clutch master cylinder replacement Trigger Defender Technical Discussions 20 July 8th, 2015 08:01 PM
Clutch Master Cylinder Billakris Defender Technical Discussions 22 November 29th, 2011 03:02 PM
Brake Master Cylinder Leak chris snell Defender Technical Discussions 12 September 28th, 2011 09:50 AM
Master Brake Cylinder Replacement: Questions! NC Rover Defender Technical Discussions 2 April 7th, 2011 12:20 PM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 10:10 PM
