PO intercooler FU connection to intake... - Defender Source
Old February 11th, 2015, 10:51 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
The po fitted a big ass intercooler with some custom piping, but for all that trouble look at the collapsed flex pipe into the intake! I have to play with this because its got to be starving for air...I should be able to use some 90's to rig something up...anyone have some ideas before I piecemeal something....
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old February 11th, 2015, 10:57 PM
silicone 90 and some unions. Guessing that when under boost its not kinked/collapsed. Sometimes you can shift things around and alleviate stuff like that.
Old February 11th, 2015, 11:05 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
It's kinked pretty good....unless it had a KKK turbo from a Porsche 930 it's not expanding. ...I am going to try some 90's. ..
Old February 11th, 2015, 11:22 PM
I remember my KKK's fondly.
Old February 12th, 2015, 12:01 AM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Think one of those would blow that little 2.5 to bits...lol
Old February 12th, 2015, 12:44 AM
psykokid
Jake
1997 Disco
That sharp 90 degree pipe coming off of the pressure side of the turbo isn't doing your airflow any favors. You generally want to keep any bends in the intercooler piping as smooth as possible.
Have any other pics of differnt angles of that hose going to the intake manifold? Cant see where it's coming from so cant really make any suggestions on how to tackle fixing it.
Old February 12th, 2015, 05:33 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Here are a few more angles...you can see how it goes from the pressure side of the turbo then across the front of the fan and into the intercooler....then from the bottom of the intercooler it climbs up into the collapsed tube into the intake manifold...
ID:	113610   Click image for larger version
Old February 12th, 2015, 06:22 PM
psykokid
Jake
1997 Disco
See notes on pics
ID:	113622   Click image for larger version
Old February 12th, 2015, 07:39 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Thanks Jake...hopefully I can 1hp...lol
Old February 13th, 2015, 07:47 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
If interested in a proper Intercooler and pipe set let me know. Can supply you with a. Nice Uprated model without all that crazy pipe work. Those bends are killing the flow.
Legend in My Own Mind.
Old February 13th, 2015, 02:38 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Would the rad have to be changed? I thought the original 2.5 TD had a smaller Rad with the Intercooler beside it...
Old February 13th, 2015, 02:51 PM
psykokid
Jake
1997 Disco
How big is the intercooler that the PO put in there?
Just remember that a more efficient intercooler setup will actually lower what you see as far as boost pressure as the pressure is also a measure of the restriction in your inlet side plumbing. Lower pressure but increased flow for the same volume of air in a more efficient system.
Old February 13th, 2015, 02:59 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Its the full size of the radiator made by Allisport...
Old February 13th, 2015, 04:05 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Ah that's a 2.5td. Thought it was a 200. Let me look into this. Do you have any pics of what you have in there now? Pm me
Old February 13th, 2015, 09:51 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Not a great photo thru the grill...but you get the idea...I am not too far from Clifton...would love your opinion on the D90 as a whole...
Old February 14th, 2015, 07:18 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Ok let me look into this
rover connection Ray Bone Defender Technical Discussions 0 September 26th, 2006 12:37 PM
Dual Optima connection options btate Defender Technical Discussions 4 June 5th, 2006 06:01 AM
Think there is a connection? JohnK Misc. Chit-Chat 2 April 6th, 2005 01:16 AM
140amp alterantor from rover connection - ROCKS! solihul Defender Technical Discussions 5 March 19th, 2005 02:42 PM
Server Connection Problems chrisvonc Community News & Announcements 1 July 25th, 2004 10:22 PM
