Pnew style Defender door bottom seals - Defender Source
Old March 20th, 2016, 06:47 PM
4RF RDS
Kevin
2000 110 XS CSW
Recently I installed the Puma style door bottom seals on my 110. They seal much better and no drafts in the corners, no water leaks in when fording either. Just thought I'd share.
The uprated door seals are only made by LR. Front door seal is universal and the part number is LR029309. Rear passenger doors are sided and the part numbers are LR029307 and LR029308. They require a couple of extra holes to be drilled in the doors to allow fitting and while designed for Puma doors fit older style square welded doors just fine.
Cheers
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Old March 20th, 2016, 09:25 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
What did you pay for them and where did you get them?
Old March 20th, 2016, 10:32 PM
Jbullis's Avatar
Jbullis
Jason Bullis
1994 NAS 90 #1810, 2006 LR3
http://www.defendersource.com/forum/...ade-46114.html
Old March 20th, 2016, 11:11 PM
doktorno
Chris deZ.
1995 Defender SW
Rather than drilling new holes to rust in the bottom of the doors, using the old seals as templates I used a dremel tool to make new holes in the rubber seal, and just relocated the plastic anchoring pins to match the existing holes in the doors. Seals are a big improvement.
Old March 21st, 2016, 09:05 AM
4RF RDS
Kevin
2000 110 XS CSW
Good idea!
Old May 22nd, 2016, 11:11 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yeah, I'm glad I read this first- ha ha
A few of the center holes actually lined up, then I re-drilled new holes in the rubber using your Dremel method.
test fit pics
ID:	150015   Click image for larger version
Rent my
Old May 22nd, 2016, 02:00 PM
Oh, you just put them on the square-cornered doors, and it looks like it works ok. I had thought about modifying the corners with a curve, but maybe I'll try this simple approach first
defender, door, seals
NAS style AC dashboard LHD , dash bottom and more rivermike For Sale - Parts 12 January 14th, 2017 08:40 AM
TD5 bulkhead vent seals vs. NAS seals Tyler Wirken Defender Technical Discussions 11 March 14th, 2011 10:22 PM
Badger Half Cab Set Up, Black, Fabric Door Seals, 94 Style $1200 evilfij For Sale - Parts 15 January 1st, 2010 10:44 PM
110 Bottom Door Seals bjf Defender Technical Discussions 3 March 11th, 2009 08:57 AM
Help Needed - NAS 110 New Style Door Sill Seals R. Kurk Defender Technical Discussions 14 December 12th, 2008 11:48 AM
