Plug and Play Projector Headlights - Defender Source
Old November 23rd, 2013, 07:33 PM
dapperlighting
Ben
Hey guys, I'm Ben with Dapper Lighting. I've been getting a TON of Defender owners contacting me and purchasing our 7" kits. I wanted to see if anyone would be interested in a kit at a discount price in exchange for some high resolution pictures and possibly a write up?
You can check out the kits here: http://www.dapperlighting.com/collec...tor-headlights
We can extend a 30% discount to anyone who is willing to help us out. Feel free to ask us any questions.
Thanks!
Ben
Old November 23rd, 2013, 07:37 PM
jafir's Avatar
jafir
Jafir Elkurd
Are these for HID or halogen?
dapperlighting
Ben
They come with halogen bulbs but you can upgrade to HIDs. You just need to refocus the projector for the HID bulbs.
Old November 23rd, 2013, 07:43 PM
Are they highway legal?
Is a relay harness part of the package?
Shipping cost to Scottsdale, AZ?
Old November 23rd, 2013, 07:46 PM
dapperlighting
Ben
HID's aren't legal so technically no. If you run them as a halogen kit then they meet FMVSS108.
Most customers run a 5K HID kit and have them pointed correctly.
A HID relay harness is included with the halogen and HID versions. I do have some halogen relay harnesses as well.
Shouldn't be more than $12-14 shipped to AZ.
Old November 23rd, 2013, 07:55 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
I may be interested in this. They might ultimately end up on a classic range rover as I need to upgrade the lights anyway, but I can absolutely takes pictures and do a small write up on the defender.
Halogen obviously. I'm not running illegal HID's, but I would be okay with non DOT approved projector halogens. I can show you pictures of my truck if you'd like?
Here's one I had on hand.
Old November 23rd, 2013, 08:00 PM
BlackField's Avatar
BlackField
Oscar
D110
What exactly do you mean by "HIDs are not legal"?
Old November 23rd, 2013, 08:01 PM
dapperlighting
Ben
Maybe shoot me an email at ben@dapperlighting.com and we can discuss specifics. Thanks for your quick responses.
We would ideally like one person for each of our kits: Chrome Classics, Black Classics, and Modern.
------ Follow up post added November 23rd, 2013 07:09 PM ------
It is illegal to retrofit HIDs into any vehicle that they did not come stock on. So unless the car came stock with HIDs, you can't legally install them. However people still continue to run them.
Personally, I believe running them in a proper housing which is correctly aligned isn't an issue but still illegal.
They actually did a study that showed people weren't bothered by the color (as most people tend to associate the white/blue lights with HIDs), and were bothered by the optics of the housing.
The issue is most people running HIDs are putting them into halogen reflective housings which causes people to associate white or blue lights as annoying or blinding. When really, a high wattage halogen bulb that is improperly aligned can be just as annoying or blinding. The important thing is to just make sure you're running everything with proper housings that are aligned correctly.
Hopefully that makes sense. I can post the study if anyone is interested.
Old November 23rd, 2013, 08:24 PM
BlackField's Avatar
BlackField
Oscar
D110
Ahhh gotcha. Thanks
Old November 24th, 2013, 07:22 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
It's legal to retrofit HID's to vehicles that didn't come with them, provided it's a complete assembly. What is not legal is retrofitting HID bulbs in to housing /reflector/lens assemblies designed for Halogen bulbs.
Here's a link to a post I made on several Rover forums.
http://landroverforums.com/forum/mod...adlamps-39755/
I think I never posted it here because since we have 7" round headlights and there are 7" round HID assemblies on the market that meet FMVSS 108 requirements.
Also, there's a lot of good technical information about lighting, including some of the physics, here: http://www.danielsternlighting.com/t...lbs/bulbs.html
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 24th, 2013, 09:31 AM
Are they sealed? How do they hold up when submerged underwater?
Old November 24th, 2013, 05:40 PM
dapperlighting
Ben
It's illegal because all DOT HID kits use HID bulb sizes such as D2S, D1S, etc. A housing designed for halogen is going to come with H1, H4, etc type bulbs. They never made DOT HID bulbs with aftermarket bulb sizes so you could run a DOT ballast but the bulbs will be aftermarket and non-approved. There is only 1-2 HID 7" Projector setups that are approved (that I know of). STARR being one of them, cost $700-$1000 and look hideous.
The only opening is a bleed valve on the top of the back side. The rear bulb area is protected with a fairly tight grommet. I've never tested submerging the units. I would probably add some extra protection if you know you are going to submerge the units. The HID kits should be fine.
Old November 24th, 2013, 08:11 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Yes, that's what I said, it's illegal to install HID bulbs in Halogen assemblies.
Aftermarket doesn't have anything to do with it.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 24th, 2013, 11:49 PM
Bolson
Ben Olson
1995 Defender 110
Not much to add regarding legality, but if you piss a cop off so bad that he's checking your headlights for DOT stamps ..... You're already screwed
Old November 25th, 2013, 05:36 AM
Antichrist's Avatar
Antichrist
Tom Rowe
I don't think it's a matter of pissing them off. It's impossible for HID bulbs to produce correct lighting when retrofitted to halogen housings. All they have to do is notice that, which is often easy to see.
That's the risk to a driver. The risk to a business selling them is that the NHTSA can make them not only refund the cost of them to all purchasers, but also cover the cost of fitting approved replacement lighting.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 25th, 2013, 08:42 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
I'd be game to consider this (Halogen) if someone can confirm that getting splashed when really warm with really cold water will not crack them. I have seen this happen with other lights (not the stock ones).
MonLand
1995 D90 NAS
1996 Discovery NAS
Old November 25th, 2013, 08:48 AM
I'm sure these are great off road, but on the highway they would be blinding to oncoming motorists. I've been dazzled by cars with HIDs and it's rather disturbing, especially in bad weather.
Old November 25th, 2013, 09:00 AM
http://www.southeastoverland.com/ind...ategory_id=114
Another option, he is on the facebook and has been posting photos and what not
Old November 25th, 2013, 09:37 AM
Antichrist's Avatar
Antichrist
Tom Rowe
I have my doubts that those would be legal when used in halogen assemblies.
I could be wrong, there could be some trick design that makes the LED output the same shape as a halogen bulb output. I just doubt it.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 25th, 2013, 11:09 AM
WD90's Avatar
WD90
Dan
1995 NAS Defender 90
I may be interested in an HID replacement for my Defender... if you could email me some info about the specific kit you are talking about and pricing, I'd be fine with providing pictures and a write up.
My email is: dan@landrovergreenville.com
ht, lights
supercharger with Plug N Play MegaSquirt ECU cdb For Sale - Parts 1 September 19th, 2011 04:47 PM
ECR LED Group-Buy JimC The Vendors Loft 63 January 17th, 2007 04:53 PM
