Plug & Play LED light kit - Defender Source
Old April 30th, 2016, 10:34 AM
searching around but didn't see it here- is there a kit out there that is plug and play? I.e. no cutting of the existing wiring for all the tail from lights?
Wipac makes one for ROW trucks but NAS seems to be left out.
thanks
if i missed it in search let me know
95' D90 - daily driver..
Old April 30th, 2016, 11:07 AM
NAS trucks have the later style waterproof connectors don't they?
Some lights come with the connectors installed so there should be no wiring changes.
Old April 30th, 2016, 01:46 PM
Plug and play is fine if the plugs are good. But time and corrosion make cut/solder/reconnect waterproof a better long term solution.
Old April 30th, 2016, 02:17 PM
Does anyone make a kit?
That was my question...
My plugs are fine there is no reason to cut them off
Old April 30th, 2016, 02:46 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Try this....
http://stores.ebay.co.uk/Bolt-On-Bit...=p4634.c0.m322
Old April 30th, 2016, 02:57 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
I have the NAS connectors if that is what you need. Male ends attach to the lights, females are to repair corroded connectors on the harness. I think i had them listed for $3 each. Free shipping with a $20 order.
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old May 1st, 2016, 01:22 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Originally Posted by rlynch356 View Post
searching around but didn't see it here- is there a kit out there that is plug and play? I.e. no cutting of the existing wiring for all the tail from lights? Wipac makes one for ROW trucks but NAS seems to be left out. thanks if i missed it in search let me know
I bought waterproof gm style connectors and a butane solder gun and I'm going for a full swap.
Old May 1st, 2016, 04:03 PM
But the 1994 and later trucks have waterproof connectors already and you can buy LEDs with the the connectors installed.
Old May 1st, 2016, 04:38 PM
Where can I buy NAS lights with the connectors ?
The RN kits don't have them they are bare wire wipac lights.
I haven't seen any since ECR stopped doing them. That I recall.
Old May 2nd, 2016, 12:09 AM
Landy_Andy's Avatar
Landy_Andy
Andy
How about following the link in post #5 above
Old May 2nd, 2016, 07:46 AM
I did, and all I saw where the smaller ROW lights in kits
Same as britpart , paddocks, Etc.
Old May 2nd, 2016, 08:50 AM
for instance - bolt on bits... ebay store has these
10 RDX LUX LED REAR NAS Lights kit Easyfit Plinths Relay Defender 1994 onwards | eBay
which come with all the parts but are a DIY for the connectors..
i really wanted to avoid issues with the wiring connections - which is where projects like this usually fail.
Old May 2nd, 2016, 09:55 AM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
I used a set of these for the rear. They are very high quality and waterproof - they need to be since they get sprayed by the rear tires. They come in 2 and 3 conductor sizes, so now I have a single connector for each light.
Angus
Old May 2nd, 2016, 10:06 AM
Exterior Lighting
Old May 2nd, 2016, 10:09 AM
Bam! perfect i totally forgot about mudstuff - and these are the same as the old ECR lights too boot.
thank you
Old May 2nd, 2016, 11:02 AM
Bolts On Bits
items in store on eBay!
ht, kit
LED Indicator set with LED license plate light & Savage Defender For Sale - Parts 2 September 8th, 2015 05:25 PM
Disco 1 "plug and play" ECU (advanced evap) One Ten The Flea Market 1 September 22nd, 2014 12:23 PM
Plug and Play Projector Headlights dapperlighting Defender Technical Discussions 22 November 25th, 2013 02:19 PM
supercharger with Plug N Play MegaSquirt ECU cdb For Sale - Parts 1 September 19th, 2011 04:47 PM
Safari Dust LED light kit? tebby Misc. Chit-Chat 10 January 5th, 2011 01:01 AM
