Plug adapter part numbers - Defender Source
Old September 16th, 2016, 12:12 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
I am swapping out early defender tail lamps for wipac LED tail lamps and am looking at a few different plug adapters. Is the rovers north part number LAH01 the same as Land Rovers STC 4637? It appears the only difference is the bullet connector.
Is there any significant drawback the just solder and shrink tubing these lights in and skipping all connectors? Seems like less to corrode.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
1971 109 3 Door (Sold)
Old September 16th, 2016, 12:23 PM
They are the same parts and both have bullets. Those are for the brake lights only. The turn signals and running lights have a two pin connector.
The downside to no connectors is you need to cut the wires when you want to remove the lights. These connectors are waterproof and won't corrode.
Old September 27th, 2016, 10:10 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Originally Posted by Red90 View Post
They are the same parts and both have bullets. Those are for the brake lights only. The turn signals and running lights have a two pin connector. The downside to no connectors is you need to cut the wires when you want to remove the lights. These connectors are waterproof and won't corrode.
Do you happen to know the Land Rover part number for the harness / plug for the clear running lights (BA 5162)?
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old September 27th, 2016, 10:26 PM
STC1188
Allbrit.de - Ersatzteile für LAND ROVER & MG ROVER
MoD trailer light plug adapter? GuamPilot Defender Technical Discussions 3 March 31st, 2013 10:47 PM
D110 new style rear door part numbers brn24whl Defender Technical Discussions 7 October 26th, 2006 12:59 AM
Need Part Numbers... Klonds Defender Technical Discussions 1 May 15th, 2006 03:03 PM
rivet part numbers? mattdh Defender Technical Discussions 0 October 29th, 2004 03:09 PM
