Plenum to air box hose - Defender Source
Old August 14th, 2007, 05:08 PM
What are the replacement options? Just take it and buy the 200$ Genuine replacement?
Old August 14th, 2007, 08:34 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
There has GOT to be some sort of hose made for somethig that could replace the stocker. What is it 3.5" air hose, mild vacuum, mild temperature duty?
Id do a bit of research for sure before shelling out $200 for two feet of cloth hose. . . .If I needed to replace mine.. : )
www.mcmaster.com Tons of hose and tubing of all materials, silicone, pvc, gum rubber, you name it. In all sizes, I even found one variety stocked in metric sizes, all available by the foot.. you're looking at $5 to $25 a foot for these. Dig around, let us know!
~Steve
Old August 14th, 2007, 08:52 PM
I will look into this. My truck is in the shop and "they" said my intake hose was split which I find sort of hard to believe. Thanks for the webpage I am going to call them and I will report back.
Old August 14th, 2007, 09:02 PM
D90DRC
D Cantrell
1997 D90SW
Rovers North has a replacement for 70.00 its a more flexible rubber hose....
Old August 14th, 2007, 09:55 PM
dkjbama
Derek Johnson
'97 D90ST - Lil' Mule
You might take a look at http://www.skidim.com/prodinfo.asp?number=MPI252-3120
Its marine exhaust hose used in boats. There are several different types on that site. The corrugated stuff might bend enough to make it fit.You might find a better online selection at boatfix.com, boatus.com , or westmarine.com
The idea just hit me reading the post. Been in boating mode for the summer so the 90 hasn't gotten much attention. :-(
Just a thought. However, the RN hose sounds like a better idea. I just like to tinker i guess.
DKJ
Lil' Mule - 1997 D90 ST Monza Red #1254
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
air filter box mattdh Wanted 1 September 14th, 2005 12:42 PM
air intake hose?? / source for cheap switches NASD90 Defender Technical Discussions 15 July 6th, 2005 02:40 PM
Air Filter Box Upgrade- Help!! alkhalifa Defender Technical Discussions 59 October 19th, 2004 04:37 AM
