Plenum Removal - Defender Source
Old March 24th, 2013, 10:40 PM
scolvus.x
John Lomax
94 ST
Plenum Removal
I'm a noob to Defenders, so aplogies in advance for silly questions. I'm replacing my fuel injectors, using the service manual. The instructions for removing the plenum include removing and clamping two coolant hoses that enter the plenum just below the intake.
I pulled those hoses no problem, but the hose connector on the plenum drained fluid like crazy. I tried collecting it, but on top of making a mess it drained at least 1/2 gallon of coolant with no signs of slowing down.
Is this something I need to find a way to collect? does it just need to drain out or have i made an error? The service manual makes no mention coolant darning from the plenum itself, so not sure how to proceed. I just replaced the hose to stop the flow for now.
Old March 24th, 2013, 10:51 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Normal, they are cooler lines, as for collecting just for disposal. I would flush the whole system if you don't know the last time it was done. Good luck have fun.
Mantec Snorkel and Custom Plenum Install Jackie Treehorn Smaller Projects 1 February 11th, 2012 03:44 PM
For Sale Bulkhead removal bar TDI Guy For Sale - Parts 11 February 2nd, 2005 08:57 AM
D90 wgn - Automatic Shifter T- Handle Removal Kimos Defender Technical Discussions 22 January 18th, 2005 07:05 PM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
