Please help me identify this missing bolt - Defender Source
Old July 15th, 2010, 09:54 PM
drv2fst
Kirk
Defender
I noticed a small drip on the garage floor and went underneath to check it out. I noticed that I am missing a bolt in a very important looking location. What goes here? What leaked out that needs to be replaced?
Old July 15th, 2010, 09:58 PM
mjekogian's Avatar
mjekogian
Michael Jekogian
1997/ Defender ST
transfercase? needs gear oil. don't drive
Old July 15th, 2010, 10:00 PM
That is the hole for the wading plug. Unless you are fording water, nothing should be there.
Ron
Old July 15th, 2010, 10:15 PM
drv2fst
Kirk
Defender
Went in for an oil change about 2 weeks ago and that is when the drops started to show up on the garage floor. Have driven about 500 miles since then. Everything seems to be working OK.
We have two very different opinions above, anyone care to break this 1-1 tie?
Old July 15th, 2010, 11:24 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
That looks like a wading plug hole. What kind of oil did you get changed? Engine or transmission/transfercase? Did you switch to synthetic? What color is the oil? What does it smell like? Gear oil has a very distinctive smell. Looks like you have an 83 done to 08 standard? Maybe an automatic box? so I doubt it's gear oil.
MUDSUX
Old July 15th, 2010, 11:35 PM
drv2fst
Kirk
Defender
It's a 5 speed manual. I had engine oil changed.
Old July 16th, 2010, 12:31 AM
Chaucer
Will
93 110 | 97 90
Pretty sure that's the wading plug hole as Ron described.
Old July 16th, 2010, 05:40 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
It's the wading plug.
SO, if oil is coming out (which it shouldn't) then either the engine rear crank seal is leaking (if the oil is black/golden) or the gearbox input shaft seal is leaking (in which case, the oil will be a red colour as the gearbox takes ATF/MTF type oil)
Either way, it's engine or box out to replace said seal.
Old July 16th, 2010, 08:42 AM
drv2fst
Kirk
Defender
Hmmm, I wonder if oil is leaking from somewhere else and getting blown to that point while driving. That is the low point for that area. It is where oil would drip to if it was sprayed from elsewhere. I'll clean the aa up real good and tighten the oil drain plug and check it again in a few miles.
Old July 16th, 2010, 01:15 PM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
check your oil level. If they overfilled, this can cause the rear crank seal to leak.
I 3rd (4th, 5th) thats; the wading plug hole. Nothing should be in there unless you're wading.
Old July 26th, 2010, 10:42 PM
drv2fst
Kirk
Defender
And we have a winner!!! I checked the engine oil level. It was just overfilled by the shop.
Thanks for the help everyone.
Steering stop bolt wanted jorge Wanted 10 December 16th, 2005 05:24 PM
ss bolt kit installation question geneseemtn Defender Technical Discussions 2 December 4th, 2005 12:28 PM
Fastback install - what is missing? paulb Defender Technical Discussions 10 March 17th, 2005 12:28 PM
check a bolt size-please mattdh Defender Technical Discussions 0 April 5th, 2004 07:00 PM
