Play in Brake Pedal - Defender Source
Old April 11th, 2012, 05:59 PM
hunterjah's Avatar
hunterjah
Jesse Hardin
Past: '97 D90 LE #135
Play in Brake Pedal
I have some play in my brake pedal, as in the pedal will "wiggle" a bit when you depress it. There's a bushing in the brake housing that the pedal attaches to (as I understand it). Does anyone know of this bushing I'm speaking of? If so, would you have any ideas where to source a replacement?
Current Stable:
2016 BMW M3 (Mineral Grey)
2013 Ford Raptor (Tuxedo Black)
Previous Rovers:
1997 LR D90 LE - #135
1997 LR D90 ST - #1185 (BRG)
2000 LR Discovery SII (Oxford Blue)
2008 LR LR3 HSE (Alaska White)
2012 LR LR4 Lux (Fuji White)
Old April 11th, 2012, 07:11 PM
I'd like to know the fix for this too but I assume it's the bushing.
Originally Posted by pendy
I'm here for the D's
Old April 12th, 2012, 02:26 PM
It is like a $10 part from rover last I checked. Keep it greased and it would have lasted for ever.
Old April 12th, 2012, 03:16 PM
hunterjah's Avatar
hunterjah
Jesse Hardin
I just bought it and it was this way when i did my pre-purchase. Didn't think it was a big issue. Per my mechanic, this has long since been unavailable. I'll do some more digging.
Current Stable:
Previous Rovers:
Old April 12th, 2012, 03:34 PM
Either I just never noticed or mine has worsened over the last 8 years to the point where I have noticed it.
I just looked. I believe we need two of these
http://roversnorth.com/store/p-8107-...wer-pedal.aspx
Amazingly it's barely cheaper overseas
http://www.paddockspares.com/564816-...ake-pedal.html
http://www.lrseries.com/shop/categor...earch+the+shop
A bit steep. There is an access hole but I am not sure if you can pull the pedal without pulling the whole box, but if so it should be relatively easy to replace them. If you have to pull the box, I'm not sure it's worth the hassle
Old April 12th, 2012, 04:56 PM
hunterjah's Avatar
hunterjah
Jesse Hardin
I found the whole brake pedal diagram on page 6 in the brake section of the RAVE manual. It looks fairly complex, but I'm going to show this to my mechanic to see if he thinks this will work, unless you want to be the guinea pig! Thanks for finding the bushings. It's not mission critical for me, but I've been knocking out some of these little annoyances and thought it might be time to try this one.
Current Stable:
Previous Rovers:
Old April 12th, 2012, 05:04 PM
I can assure you that at the current rate I am tackling projects on the D90, this will not happen for me in a time frame measured in years
Old April 13th, 2012, 03:13 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Is this an easy spot to grease?
1997 P38 4.6
1998 P38 4.0
2011 LR4
brake
Quick Steering Fix - play in the steering wheel. bossman429 Defender Technical Discussions 5 February 27th, 2012 08:37 PM
acceptable play in drive shaft ? Chris Velardi For Sale - Parts 2 October 28th, 2011 12:43 PM
supercharger with Plug N Play MegaSquirt ECU cdb For Sale - Parts 1 September 19th, 2011 04:47 PM
drive shaft play bjenk Defender Technical Discussions 0 June 29th, 2007 12:27 AM
Employment opportunity Rod Hayward Misc. Chit-Chat 18 December 20th, 2005 10:20 PM
