Plastic Wheel Arch Rivets - Defender Source
Old February 17th, 2014, 12:10 AM
rgrrvr's Avatar
rgrrvr
DJ Menasco is The Dude
1995 D90
What is the right way to do this? I tried to back the center pin out and push them in flange side first but then cant get the center pin in to spread the flanges. Is the correct way to have the center pin out through the flanges and then press it back in? Im totally confused.
Keith
...you'll feel better in a couple of days.
Old February 17th, 2014, 12:18 AM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
No, once out you just keep the center pin out and then push the rivet into the hole and then push the center pin back in. I found it was best to just buy a bunch that way when you take them out you can just yank on it {which is what she said}.
Old February 17th, 2014, 12:28 AM
rgrrvr's Avatar
rgrrvr
1995 D90
Installing. The problem is that I cant get them from reset to installed once I get them in the hole. The pin keeps bending. Yours look more sturdy than mine though.
There are so many things wrong with that statement...
Old February 17th, 2014, 01:22 AM
El Solis's Avatar
El Solis
Chris Solis
I just used either my hand to push it in or a rubber mallet. Worked fine.
Old February 17th, 2014, 11:06 PM
Green Blood's Avatar
Green Blood
Carl Phillips
1988 90- Swiss LHD 2.5 Petrol
If you have the type I did with the small, center pin, I found I just kept bending or breaking them when I tried to use a hammer or mallet to drive them in.
The best way I found to insert them was to use a brad driver. Kind of hard to explain without photos (which I have somewhere) but this was the type of brad driver where you inserted the brad in the hole at the end and then give the end of the tool a swift push to drive the pin into the rivet.
Totally confused now? Take a look at this and I think you'll get the idea of how it might work:
http://www.amazon.com/Robert-Larson-.../dp/B0012XR9QW
Cheers,
CARL
Proud restorer and former owner of '94 NAS D90 #590- back in the hands of its original owners.
And now happy owner of a 1988 Swiss-Market D90 Station Wagon.
wheel
defender wheel arch removal isleofbones Defender Technical Discussions 5 April 4th, 2009 08:04 PM
Extended wheel arch flares? THP90 Defender Technical Discussions 1 August 31st, 2005 02:26 PM
Need plastic rivets to hold side step Campbell Wanted 2 March 21st, 2005 04:41 PM
Wheel Arch Protectors/Eyebrows boshea Defender Technical Discussions 2 June 29th, 2004 11:28 AM
Wheel Arch Eyebrows boshea Wanted 0 June 23rd, 2004 08:57 PM
» Defender Registry
White
KGH
110
Mes788
Add your Defender
