Plastic tubes around fuel injectors??? - Defender Source
Old May 22nd, 2015, 09:12 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Hi guys. Thanks for the always great advice.
So my buddy mechanic who struggles with English is swapping on the fuel injectors on my 1994 D90 NAS. He asked me to reach out to you all to ask about the plastic sleeve or tube that holds or has to do with the injectors???? He's new from Kosovo and normally I understand his extreme broken English.
Anyway, he suggests we replace them. Any clue?
Old May 22nd, 2015, 09:34 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
o-rings?
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old May 22nd, 2015, 09:36 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Nope. I bought replacement o-rings. No clue what my buddy is referring to. He mentioned never seeing these "tubes" in any car he's worked on before.
Old May 22nd, 2015, 09:52 PM
There are plastic tubes over the nozzles to protect them until you install.
Old May 22nd, 2015, 09:54 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Thanks but interestingly that isn't it either...I'm dropping off the new injectors tomorrow, so he must be referring to something in the Defender????
Old May 22nd, 2015, 10:04 PM
Ignotus
gene
1960 109, w/200TDI
spill rail?
Gene
1960 109
1960 88 Ignotus
Blog;
Old May 22nd, 2015, 10:05 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Ok cool! I'll have to google what a spill rail is.
Old May 22nd, 2015, 10:07 PM
Ignotus
gene
1960 109, w/200TDI
spill rail is the tubing which the fuel passes from injector to injector and returns excess fuel to the tank
Gene
1960 109
1960 88 Ignotus
Blog;
Old May 22nd, 2015, 10:09 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
That must be it. I googled it and it's all coming together now. Is now a good time to replace? Pain in the @ss? He mentioned it looked beat up. So if bad and the gas doesn't return to the tank, would that cause flooding?
Old May 22nd, 2015, 10:18 PM
Ignotus
gene
1960 109, w/200TDI
Wait, this is gas? I thought it was diesel injectors. I know nothing of V8 gas fuel injectors, other than I think they are called fuel rail not spill rail. Probably because they don't go back to the tank. Unless someone else chimes in you are probably going to have to put eyeballs on it. Sorry...
Gene
1960 109
1960 88 Ignotus
Blog;
Old May 22nd, 2015, 10:19 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Haha yeah gas not diesel. But I think you're on to something.
Old May 22nd, 2015, 10:26 PM
Is not the fuel rail steel?
Old May 22nd, 2015, 10:34 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
No clue. This is way above my pay-grade. My buddy was referring to a plastic tube related to the fuel injectors being replaced.
Old May 23rd, 2015, 07:11 AM
Is he talking about the O-rings that seal them into the head?
I don't think you should attempt to change them.
Old May 23rd, 2015, 07:13 AM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Nope not o-rings. Those come new on new injectors. I sent him a photo of a fuel rail. Waiting to get his response.
Old May 23rd, 2015, 07:33 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Is he talking about the boots on the harness?
Old May 23rd, 2015, 07:34 AM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Those sure look like "plastic tubes"!!! Awesome. He said they look beat up and need to be replaced. Now, I'll start googling that. Awesome. Thanks!!!
Old May 23rd, 2015, 10:46 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I'd be interested if you go that route of replacement as there is no easy way as far as I know to do it. Mine are cracked--I believe you would either need to cut them off and get new connectors and boots or buy a new fuel rail harness and splice it on. Both would be tedious and I have no clue where you would get the parts but if you DO go this route, let me know and the next time I rebuild my engine or have that part apart, I might replace mine. In the interim, I used RightStuff on all my cracks--I cleaned the boots with rubbing alcohol and just dabbed on the right stuff. It has stayed flexible and worked great.
On a side note, the fuel rails sometimes need replacing. I have seen them so badly rusted and pitted that I would never reuse them. I believe they have a cadium coating due to the yellowish color but they do go bad. Yours do not look bad, though.
fuel
US source for Michelin Airstop tubes? jhealey Series Technical Discussions 1 June 17th, 2015 07:34 AM
Breather Tubes Bill Larson Misc. Chit-Chat 2 December 31st, 2014 02:44 PM
'97 D90 NAS side step tubes: pickup middle TN Nashville For Sale - Parts 7 June 5th, 2014 09:49 PM
WTB NAS ST connector tubes between A and B pillar dave_lucas Wanted 4 December 29th, 2011 02:14 PM
stainless brake tubes mattdh Misc. Chit-Chat 25 December 12th, 2003 07:14 PM
