Plastic Fuel Lines, what to use? - Page 2 - Defender Source
Old January 1st, 2016, 10:42 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
I'll have a more detailed look through your link.
I had been thinking of utilizing small rubber sections with clamps to bridge between the steel pipe and the lines. However compression fittings would be nicer.
I'll have to head out to the cold workshop and take some measurements of the pipes.
Old January 1st, 2016, 11:20 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I ran rubber lines - easy to get a my the local Napa also simple and durable like RD said. I ran my up the top of the left side frame rail as the OM617 has its fuel setup on the left side and the right side had some brake lines. The frame had a few holes where I used some nutserts (m5 IIRC) and used plastic hose clips with bolts to secure. I'm happy with the results. There should be some pics of it on the OM617 or my build thread.
fuel
Anyone else use Power Services Diesel Fuel Conditioner year round? KevinNY Defender Technical Discussions 7 October 28th, 2016 05:37 PM
No fuel to motor after new fuel lines-help Tyler Wirken Defender Technical Discussions 7 April 22nd, 2012 03:31 PM
Is there good metal or plastic fan replacement for the plastic D90 radiator? Neil McCauley Defender Technical Discussions 8 December 12th, 2011 08:30 PM
What diameter is the plastic fuel line on a LR diesel evilfij Defender Technical Discussions 17 June 27th, 2010 11:23 PM
300 / TD5 110 plastic fuel tank kits FS SafariHP The Vendors Loft 6 December 17th, 2008 09:47 AM
