Place your bets, Blown head gasket, or cracked manifold? - Defender Source
Old February 7th, 2008, 01:03 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Started to rain, so I had to give up on it for now. Not to mention, the diagnostic tool I need is at somebody else's house right now.
Symptom is, sounds like an exhaust leak. Replaced all the manifold gaskets and the Y-Pipe gasket on that side, with no results. Turned off the fans, put a string on the end of a stick, and lowered it between the manifold and the block..... very actively bouncing around right in the middle. Problem is, It wiggles so much I can't tell if it's being blown outward (head gasket) or inward (manifold).
Going to stop by Mom's house where some of my tools are still stored, and pick up my compression tester. But won't be able to do anything with it until Monday probably.
It also looks like I may have a slight bit of water in my oil too. Nothing in the sump when I do a change, but I've got the happy-milk looking stuff up around the fill cap. But that may be the result of an old leak up by the intake manifold that I suspect may still be there.
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 7th, 2008, 01:23 PM
Tim Scully's Avatar
Tim Scully
Tim Scully
95 D90 SW/ 95 RR LWB
I would put my money on the exhaust manifold being cracked. I haven't seen a lot of D90s with this problem but tons of D1s had this issue.
Are you having any over heating or driveability issues? If it was the headgasket there would probably be running issues. Did you have any problems installing the manifold gaskets getting the bolts started in the head? I would bet it is the passenger side (bank b) of the engine as well.
Old February 7th, 2008, 01:48 PM
Hans's Avatar
Hans
Hans Haase
Drivers side, and no problems getting the bolts started. Looks to be associated with one of the two middle cylinders. Though I only did one gasket at a time, since the 3.9's need to use the individual gaskets. Tried the paired ones once, the connector piece interfered with the ARP head studs I was using.
Not too worried if it is the head gasket. I've been wanting to re-do the valley gasket for a while anyways. Will be much easier doing just one side as opposed to last time when I did both sides along with a new cam. Pulling the front cover is such as pain in the ass, have to worry about re-timing the ignition, priming the pump, cracking a bolt for the water pump and having to take it all off again to bring the front cover to a machine shop to get the bolt out and heli-coil the old hole.......
Nope, not too worried about one head gasket at all.
-Hans
My oil line fix
Old February 7th, 2008, 04:26 PM
Hans's Avatar
Hans
Hans Haase
And this winner is......
Head Gasket!
2nd cylinder on the left side is down about 60psi. And while I was doing the compression test, silly me also forgot to depressurise the fuel system. Eventually the engine flooded, and that let me visually see exactly where the leak is coming from. Working on a parts list now, will order them tomorrow.
-Hans
My oil line fix
Old February 9th, 2008, 01:01 PM
Tim Scully's Avatar
Tim Scully
Tim Scully
Hahahaha. Good work man. Have fun on the head gasket.
Old February 29th, 2008, 02:21 PM
Hans's Avatar
Hans
Hans Haase
Finally all done. Cleaned up a few other issues while I was at it. Big annoyance was that first the lower radiator hose ended up being bad.... had to order it and wait. Installed that, and the water pump ended up being no-good either. Had to order THAT and wait.
All done now, I hope.
-Hans
My oil line fix
Old February 29th, 2008, 03:00 PM
Did you switch to composite gaskets? Did you resurface the heads?
Old February 29th, 2008, 03:47 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Good to hear Hans - hope things are all buttoned-up for you.
Old February 29th, 2008, 04:10 PM
Hans's Avatar
Hans
Hans Haase
Switched to the composite gaskets, not worth it to resurface the heads on a 125k mile engine.
That can wait until I do a full rebuild at some point.
My oil line fix
Old March 20th, 2008, 09:24 AM
bcourtney's Avatar
bcourtney
Robert Courtney
1973 Series III 200TDI
Hans did you change to the stretch bolts when you re-assembled? I just did the same job, but resurfaced the heads while I was at it, and used the stretch bolts and composite gasket. The kit I got from AB uses only 10 bolts instead of 14. I took great care in re-assembly, but discovered after a week coolant leaking out between the head and block at the back. With the stretch bolts you can't re-torque, so I'm afraid I have to start over, unless anyone has thoughts on this.
Old March 20th, 2008, 02:34 PM
Hans's Avatar
Hans
Hans Haase
I had originally done both head gaskets a couple years ago, and when I did that I opted to use the ARP head studs. Since these are torqued normally, I re-used them. The stretch-bolt thing I must admit is really annoying for folks that do a lot of engine work.
But are you sure that it's leaking between the head and block? Could also be leaking between the head and intake manifold too. And the manifold bolts should be retorqued after a few heat cycles.
-Hans
My oil line fix
Old March 20th, 2008, 04:26 PM
bcourtney's Avatar
bcourtney
Robert Courtney
-Hans
According to LR you don't retorque stretch bolts, as there is no torque setting except the first turn. When you use these bolts, you go to 15 FP wait 20 min, turn them 90degrees, wait 20 min, and turn them another 90degrees.
Old March 20th, 2008, 08:02 PM
bcourtney's Avatar
bcourtney
Robert Courtney
Hans thanks for waking me up. Just checked, leaking at the manifold and running down.
ac, gas, rack
Cracked Exhaust Manifold jamieh64 Defender Technical Discussions 9 November 22nd, 2005 01:04 PM
D90 head gasket lead--which one? Davis Defender Technical Discussions 6 April 1st, 2005 11:52 PM
d90 dead 4 hours from home! head gasket? vesparover Defender Technical Discussions 4 August 17th, 2004 04:47 PM
