Pitman arm Picture - Defender Source
Old February 26th, 2006, 02:36 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Pitman arm Picture
Hey,
Can somebody post a picture of a stock pitman arm. Demensions would be really cool too is someone has them! Thanks!
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 26th, 2006, 09:51 AM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
Which dimensions?
ID:	5144   Click image for larger version
Old February 26th, 2006, 02:23 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Originally Posted by Rod Hayward
Which dimensions?
Thanks a lot! I needed lenth and drop but I can tell from the pics that it will not work for what I was going to try. Thanks again!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 26th, 2006, 09:59 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
You're smokin that stuff again aren't you David?
Keith
Keith
Big, Red and ... aaa Red..
Old February 26th, 2006, 10:13 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Keith
Again? I never stopped! Actually, I have an issue. I switched my tie rod over to the top of the d60 knuckle and now at full straight compression (not articulation) the tie rod comes up and hits the pitman arm. I am trying to solve this without machining a pitman arm. I think I might just put the pitman arm on upside down and revers the hiem, it will net me one inch. But the best thing to do is machine a flat pitman arm. Actually, a picture is a lot easier.
ID:	5151   Click image for larger version
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 27th, 2006, 01:11 AM
Scott 9835
Scott Falter
95 D90
Cool Heat it up
Get a torch and heat the ____- out of it and bend it. It will bend but make sure you take it off the box so you dont burn the seals up. Put it in a vise heat it up so it is bright red and have friend (if you got any) bend it with a wrench or pipe. You can bend any way you want. Let it cool by it self. Dont add water or anything else. I have done it before and it works good.
Old February 28th, 2006, 01:16 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I never thought of that. Its a good idea, thanks. I think I am going to source another Ford one, and if I can't find the right one, I will try this!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 4th, 2006, 06:02 PM
Use a disco pitman arm and weld and remachine it for the ball joint to sit on top.
Wanted: d-90 pitman arm, Defender Cross Rod End Blakesrover Wanted 6 September 25th, 2009 08:38 PM
Pitman arm to Steering box question dmarchand Defender Technical Discussions 3 September 5th, 2008 11:53 PM
Pitman Arm 97 D-90 97Ariesblu Wanted 12 May 20th, 2007 09:35 AM
Need new drag link & pitman arm !? Rover- Girl Defender Technical Discussions 4 March 23rd, 2006 06:33 PM
little piece that steering damper mounts to near pitman arm evilfij Wanted 4 October 5th, 2004 08:55 PM
