Pintle hitch bolt length - Defender Source
Old November 15th, 2006, 11:54 PM
Nigel
Ted Constantine
I am throwing a pintle hitch on the rear of the 90. Does anyone know how long the bolts need to be? I would rather have the right bolts before I drop the skid plate and tank.
Old November 16th, 2006, 11:37 AM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Don't really know as I don't know the thickness of the pintel. But I used 4.5" bolts for my set up, which was the 5T jaw
5/8", the receiver plate 3/8, the EE backing plate 3/8. 4" would have done it as well. If you are using a backing plate
(which you should), then your bolts would be similar in length, I would say 4" would cover it.
Better to measure everything out, and better to have a little room to work with on the bolts. You don't want them too short or just enough for the nut.
Old November 16th, 2006, 08:27 PM
rvrchuck's Avatar
rvrchuck
Chuck Hester
1995 D90
Absolutely make sure to fab up a backing plate. That rear x member will not hold up well on its own. I had my bolts welded to my plate, I think they were 5".
Roverin' Chuck
'95 AA Yellow 90
hitch
Old, Series style Pintle hitch. Rotating. well used. dmarchand For Sale - Parts 2 June 24th, 2008 01:58 PM
Flush mounted rotating Pintle Hitch dmarchand Wanted 12 May 9th, 2008 12:51 PM
11,000lb pintle hitch for sale mountainviewrover For Sale - Parts 7 December 1st, 2006 08:49 AM
Bolt length needed to install Dixon Bate ronward Defender Technical Discussions 2 September 11th, 2004 06:05 PM
